Commonwealth Bank of Australia
Last activity: 4 May 2018 0:15 EDT
Getting CICDLogHelper error when using deployment manager to deploy application
HI,
Below is the error when I try to deploy application from dev to test environment using Pega deployment manager
HI,
2018-05-03 11:54:18,666 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ ] ( pega.jsr199.Jsr199Bridge) ERROR deploymanager - Failed to compile rule: /com/pegarules/generated/activity/ra_action_pzcreatetaskwrapper_0bece77cd6628dd684d383f4ac46d83f.java
2018-05-03 11:54:18,787 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ ] (ernal.cache.AssemblerFunctions) ERROR deploymanager - The rule which attempted to use a non-accessible jar during rule compilation is: "com.pegarules.generated.activity.ra_action_pzcreatetaskwrapper_0bece77cd6628dd684d383f4ac46d83f". Please see error above for non-accessible jar information.
2018-05-03 11:54:18,787 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ ] (sm.VirtualTableAssemblyHandler) ERROR deploymanager - Failed to compile com.pegarules.generated.activity.ra_action_pzcreatetaskwrapper_0bece77cd6628dd684d383f4ac46d83f, pzInsKey = RULE-OBJ-ACTIVITY PEGA-INT-PIPELINE PZCREATETASKWRAPPER #20170731T083319.331 GMT; see class's compile log file.
2018-05-03 11:54:18,790 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ ] ( internal.mgmt.Executable) ERROR deploymanager - FirstUseAssemblerException
com.pega.pegarules.pub.generator.FirstUseAssemblerException: Failed to compile generated Java com.pegarules.generated.activity.ra_action_pzcreatetaskwrapper_0bece77cd6628dd684d383f4ac46d83f: ----------
1. ERROR in /com/pegarules/generated/activity/ra_action_pzcreatetaskwrapper_0bece77cd6628dd684d383f4ac46d83f.java (at line 426)
CICDLogHelper.addAppender();
CICDLogHelper cannot be resolved
2. ERROR in /com/pegarules/generated/activity/ra_action_pzcreatetaskwrapper_0bece77cd6628dd684d383f4ac46d83f.java (at line 880)
logContent = CICDLogHelper.getAppenderContentAndRemove();
2 problems (2 errors)
Compile failed.at com.pega.pegarules.generation.internal.vtable.asm.VirtualTableAssemblyHandler$1.call(VirtualTableAssemblyHandler.java:497) ~[prprivate.jar:?]
at com.pega.pegarules.generation.internal.vtable.asm.VirtualTableAssemblyHandler$1.call(VirtualTableAssemblyHandler.java:394) ~[prprivate.jar:?]
at com.pega.pegarules.generation.internal.vtable.VirtualTableUtils.doWithFilteredRulesetList(VirtualTableUtils.java:282) ~[prprivate.jar:?]
at com.pega.pegarules.generation.internal.vtable.asm.VirtualTableAssemblyHandler.assemble(VirtualTableAssemblyHandler.java:394) ~[prprivate.jar:?]
at com.pega.pegarules.generation.internal.vtable.asm.VirtualTableAssemblyHandler.assembleForAspect(VirtualTableAssemblyHandler.java:186) ~[prprivate.jar:?]
at com.pega.pegarules.generation.internal.vtable.asm.VirtualTableAssemblyHandler.lookupForAspect(VirtualTableAssemblyHandler.java:136) ~[prprivate.jar:?]
at com.pega.pegarules.generation.internal.vtable.containers.AspectOnlyRuleContainer.upgrade(AspectOnlyRuleContainer.java:79) ~[prprivate.jar:?]
at com.pega.pegarules.generation.internal.vtable.ruleres.VirtualTableCandidate.upgradeContainerFor(VirtualTableCandidate.java:286) ~[prprivate.jar:?]
at com.pega.pegarules.generation.internal.vtable.ruleres.VirtualTableCandidate.getExecutableContainerFor(VirtualTableCandidate.java:220) ~[prprivate.jar:?]
at com.pega.pegarules.generation.internal.vtable.ruleres.VirtualTableResolver.resolveToContainer(VirtualTableResolver.java:426) ~[prprivate.jar:?]
at com.pega.pegarules.generation.internal.vtable.ruleres.VirtualTableResolver.resolveRule(VirtualTableResolver.java:153) ~[prprivate.jar:?]
at com.pega.pegarules.generation.internal.vtable.VirtualTableImpl.resolveRule(VirtualTableImpl.java:297) ~[prprivate.jar:?]
at com.pega.pegarules.generation.internal.PRGenProviderImpl.get(PRGenProviderImpl.java:498) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3569) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:646) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivities(ThreadRunner.java:572) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivities(PRThreadImpl.java:473) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.executeBatchTask(QueueProcessor.java:297) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.execute(QueueProcessor.java:362) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:1055) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1304) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1052) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:934) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:761) ~[prprivate.jar:?]
at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:991) ~[prjsr166java6-3.0.jar:?]
at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:532) ~[prjsr166java6-3.0.jar:?]
at java.lang.Thread.run(Thread.java:745) [?:1.8.0_60]
2018-05-03 11:54:18,793 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ (ernal.async.BatchRequestorTask) ERROR deploymanager - Batch activity "Pega-Int-Pipeline.pzCreateTaskWrapper" threw:
com.pega.pegarules.pub.PRRuntimeError: PRRuntimeError
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:712) ~[prprivate.jar:?]
Caused by: com.pega.pegarules.pub.PRRuntimeError: PRRuntimeError
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3596) ~[prprivate.jar:?]
... 12 more
Caused by: com.pega.pegarules.pub.generator.FirstUseAssemblerException: Failed to compile generated Java com.pegarules.generated.activity.ra_action_pzcreatetaskwrapper_0bece77cd6628dd684d383f4ac46d83f: ----------
... 12 more
