Generate individual BIX XML for each case (work object)
Team,
We are executing BIX (07-10-33) in command line. Hence we create a BAT file that calls extract rule and extract rule generates XML in given folder location.
OOB implementation is XML will capture all the cases from last run and generate one single XML for all the cases. In Extract rule configuration there is no provision to generate XML for case by case. The command line has z and Z parameters which we may call in a loop in BAT file.
1. Is this approach (z/Z parameters) recommended?
2. Is there any other way of implementing the individual XMLs?
Jayantha
