NJ Courts
Last activity: 13 Apr 2017 9:41 EDT
BIX - Limit the count of the cases to be included in XML extract
We are implementing BIX with output format as "XML". The scheduler is planned to run once every night.
We have a concern that the XML size could be too large as we need to extract all the completed cases, which could be upto 80,000 as this a call center.
So how do I restrict the number of cases that can be included in one XML. So let us say if I want to limit only 500 cases per XML and generate multiple XMLs, is this configurable?
Gowri
Pegasystems
Hi Gowri,
Currently with XML extraction, there is no configuration to split the file into multiple chunks for a large extract. This would be an enhancement that the BIX product would need.
-Rajiv
NJ Courts
Rajiv,
Thanks for your response.
The extract rule does not seem to accept any parameters. Is it possible to pass parameters to this extract rules? so we can include only the cases updated in specific time range.
If we can pass parameters to the extract rule, then I can have the looping logic in the agent activity to call the extract rule with the time range as parameters
Gowri
Pegasystems
Hi Gowri,
The extract rule was mainly designed to run using the BIX command line and that is our recommended way to extracting data. When running from the command line, there is no access to parameters and thus the extract rule has not been designed to accept the same.
In command line options, you can leverage the -u and -U options to limit the ranges of records that you need to extract in one run. Please refer to the BIX user guide for details on how to run in command line - https://docs.pega.com/bix-71-user-guide
-Rajiv
NJ Courts
Rajiv,
Thanks. We are using cloud, looks like we cannot control the batch size in cloud even with command line approach
Gowri
Pegasystems
Batch size in BIX is meant for the records written to the target table. Since for BIX on cloud, we don't allow for writing the extracted data to an external DB, this option is not supported.
NJ Courts
You are right it is applicable for extracting to external DB.
So the only option is to split the file is -u and -U parameters.
I don't have much idea about writing shell scripts. But my logic should be to make this java call in a loop and pass the arguments(pxUpdateDateTime) that should be evaluated dynamically before the call,
If anyone has attempted this before, please share the code
Gowri
Pegasystems
You won't be able to use shell on the cloud. You will need to use the pxExtractDataWithArgs activity to do that - Please refer to BIX User Guide (section: Running a BIX extract in Designer Studio)
NJ Courts
Rajiv,
To summarize, if you refer to my original post, I am trying to figure out if it is doable programmatically though not supported by PEGA OOTB features.
The only option to do this is using the shell scripts and cron job, so we can pass dynamic arguments to this java call.
But then the above cannot be done in Cloud? Is that right?
Gowri
Pegasystems
You should reach out to your account executive / partner alliance to know if BIX can be supported for your version of Pega platform on Pega Cloud.
Centene
As you are talking about the call center, I hope you are using CPM framework. You can create extract rules for each type to segregate or else you can create extract rules based on the worktype.
Alternative options:
- Write different extract rules with different filtering criteria
