Capgemini
Last activity: 1 Aug 2016 4:44 EDT
File listerners are not coming up while restarting the server
Dear all,
We have created couple of new file listeners in our application.
Previous listeners used to come up automatically once the server is restarted.
But these file listeners are not coming up.
No error is also there in logs.
Pega version - Pega 7.1.8
Vishal
Message was edited by: Marissa Rogers - moved from Mesh Help, added Category
Hi Vishal,
Can you please share the File listener configuration by taking screenshots?
Capgemini
Do you mean none of the file listeners is coming up during server start up and all of them have to be brought up manually? Can you enable debug on logger com.pega.pegarules.integration.engine.internal.services.file.FileListener in prlogging.xml and restart again? You can attach the start up log here once it is ready.
=waikei
Capgemini
Yes none of the file listeners are coming up during server start up and all have to be brough up manually.
Can you please share the xml snippet to be added in prlogging.xml as I don't have this present in my current prloggin.xml file.
Best,
V
Capgemini
<category name="com.pega.pegarules.integration.engine.internal.services.file.FileListener">
<priority value ="info" />
</category>
Is this the code snippet you were mentioning??
Best.
V
PEG
Priority value should be debug.
Please note that it needs server restart to take this changes into effect.
Capgemini
also which logs to check for logs generated by this logging level changes?
PEG
PegaRules log
Capgemini
made changes to prlogging.xml file and shared the same with operations team to upload and restart the server...will share the results here on PEGAMESH...lets see
Best,
V
Capgemini
Dears,
Server started with and we can see few errors related to file-listener as well
PEGARULES logs are as below:
2016-06-13 17:47:32,028 [ server.startup : 1] [ ] [ ] (ervlet.WebAppLifeCycleListener) INFO - System Start Date: Mon Jun 13 17:47:32 CEST 2016
2016-06-13 17:47:32,037 [ server.startup : 1] [ ] [ ] (ervlet.WebAppLifeCycleListener) INFO - PegaRULES Web Tier 7.10 (ML8)
2016-06-13 17:47:32,037 [ server.startup : 1] [ ] [ ] (ervlet.WebAppLifeCycleListener) INFO - coreAssemblyCached_718_675: 2015-05-20 18.49 EDT
2016-06-13 17:47:32,037 [ server.startup : 1] [ ] [ ] (ervlet.WebAppLifeCycleListener) INFO - http://camscm/svn/PRPC_core/branches/integration/718/dev/core (136827)
2016-06-13 17:47:32,037 [ server.startup : 1] [ ] [ ] (ervlet.WebAppLifeCycleListener) INFO - Now starting the PegaRULES Web Tier...
2016-06-13 17:47:32,084 [ server.startup : 1] [ ] [ ] ( context.web.WebEnvironment) INFO - Web tier using local JNDI context
factory = com.ibm.websphere.naming.WsnInitialContextFactory
Dears,
url = corbaloc:rir:/NameServiceServerRoot
path = mco8i/nodes/oes8i1/servers/oesi_server
2016-06-13 17:47:32,084 [ server.startup : 1] [ ] [ ] ( priv.context.JNDIEnvironment) INFO - Web-tier default Engine bean name set to EngineBMT
2016-06-13 17:47:33,188 [ server.startup : 1] [ ] [ ] ( basic.config.SettingsImpl) INFO - prconfig.xml merged with prconfig entries in Data-Admin-System-Settings
2016-06-13 17:47:33,272 [ server.startup : 1] [ ] [ ] (able.DefaultVirtualTableConfig) INFO - Using Hybrid Virtual Rules Table implementation
2016-06-13 17:47:33,272 [ server.startup : 1] [ ] [ ] (able.DefaultVirtualTableConfig) INFO - VTable dispatches rules for 7 Aspects: 'Validate, When, Input, Alias, Collection, Model, Action'.
2016-06-13 17:47:33,272 [ server.startup : 1] [ ] [ ] (able.DefaultVirtualTableConfig) INFO - ABA[AC] dispatches rules for 1 Aspect: 'Stream'.
2016-06-13 17:47:33,272 [ server.startup : 1] [ ] [ ] ( priv.context.JNDIEnvironment) INFO - Enterprise-tier default Engine bean name is EngineBMT
2016-06-13 17:47:33,273 [ server.startup : 1] [ ] [ ] (r.context.EtierEnvironmentImpl) INFO - Enterprise tier using local JNDI context
2016-06-13 17:47:33,288 [ server.startup : 1] [ ] [ ] (ion.internal.PRGenProviderImpl) INFO - invokeDynamic instrumentation for inlining is not enabled: prinvokedyn.jar is not visible, or not using Java 7
2016-06-13 17:47:33,288 [ server.startup : 1] [ ] [ ] (ion.internal.PRGenProviderImpl) INFO - Assembly Version: -1551638810
2016-06-13 17:47:33,721 [ server.startup : 1] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Base database information:
2016-06-13 17:47:33,721 [ server.startup : 1] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Database name: pegadata
2016-06-13 17:47:33,721 [ server.startup : 1] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Defined by: JNDI name
2016-06-13 17:47:33,721 [ server.startup : 1] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Data source name: java:comp/env/jdbc/PegaRULES
2016-06-13 17:47:33,721 [ server.startup : 1] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Minimum connection count: 0
2016-06-13 17:47:33,721 [ server.startup : 1] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Maximum connection count: unlimited
2016-06-13 17:47:33,721 [ server.startup : 1] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Failover database: none
2016-06-13 17:47:33,721 [ server.startup : 1] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Default Schema: OES_SCHEMA
2016-06-13 17:47:33,726 [ server.startup : 1] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Base database information:
2016-06-13 17:47:33,726 [ server.startup : 1] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Database name: pegarules
2016-06-13 17:47:33,726 [ server.startup : 1] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Defined by: JNDI name
2016-06-13 17:47:33,726 [ server.startup : 1] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Data source name: java:comp/env/jdbc/PegaRULES
2016-06-13 17:47:33,726 [ server.startup : 1] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Minimum connection count: 0
2016-06-13 17:47:33,726 [ server.startup : 1] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Maximum connection count: unlimited
2016-06-13 17:47:33,726 [ server.startup : 1] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Failover database: none
2016-06-13 17:47:33,726 [ server.startup : 1] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Default Schema: OES_RULES_SCHEMA
2016-06-13 17:47:34,113 [ server.startup : 1] [ ] [ ] ( external.timers.CpuTimer) INFO - CPU timers set to TOTALSONLY. Use prconfig setting 'initialization/CpuTimerLevel' with one of [FULL, TOTALSONLY, NONE] to modify.
2016-06-13 17:47:34,115 [ server.startup : 1] [ ] [ ] (.timers.EnvironmentDiagnostics) INFO - Using Java 1.5 Thread.getAllStackTraces() for thread dumps
2016-06-13 17:47:34,420 [ server.startup : 1] [ ] [ ] (.access.PageDatabaseMapperImpl) INFO - DeflateStreams is turned ON.
2016-06-13 17:47:34,478 [ server.startup : 1] [ ] [ ] (pboard.StorageStreamCommonImpl) INFO - engineCodeVersion: 07-10-17
2016-06-13 17:47:35,974 [ server.startup : 1] [ ] [ ] ( internal.archive.ParUtilsImpl) INFO - Setting archive staging directory: /oesi/was/var/temp/PegaTempDir/RuleMgmt
2016-06-13 17:47:35,974 [ server.startup : 1] [ ] [ ] ( etier.impl.EngineStartup) INFO - JVM Information:
2016-06-13 17:47:35,974 [ server.startup : 1] [ ] [ ] ( etier.impl.EngineStartup) INFO - Vendor: IBM Corporation, JVM version: 1.6.0
2016-06-13 17:47:35,974 [ server.startup : 1] [ ] [ ] ( etier.impl.EngineStartup) INFO - VM Name: IBM J9 VM(build pxa6460_26sr8fp25-20160422_01 (SR8 FP25))
2016-06-13 17:47:35,974 [ server.startup : 1] [ ] [ ] ( etier.impl.EngineStartup) INFO - Host OS Information:
2016-06-13 17:47:35,974 [ server.startup : 1] [ ] [ ] ( etier.impl.EngineStartup) INFO - OS: Linux, version: 2.6.32-573.22.1.el6.x86_64
2016-06-13 17:47:35,974 [ server.startup : 1] [ ] [ ] ( etier.impl.EngineStartup) INFO - Architecture: amd64
2016-06-13 17:47:35,974 [ server.startup : 1] [ ] [ ] ( etier.impl.EngineStartup) INFO - PegaRULES Enterprise Tier 7.10 (ML8)
2016-06-13 17:47:35,974 [ server.startup : 1] [ ] [ ] ( etier.impl.EngineStartup) INFO - coreAssemblyCached_718_675: 2015-05-20 18.49 EDT
2016-06-13 17:47:35,974 [ server.startup : 1] [ ] [ ] ( etier.impl.EngineStartup) INFO - Deployed in both web and enterprise tier
2016-06-13 17:47:35,974 [ server.startup : 1] [ ] [ ] ( etier.impl.EngineStartup) INFO - Servlet container: WebSphere
2016-06-13 17:47:35,974 [ server.startup : 1] [ ] [ ] ( etier.impl.EngineStartup) INFO - Web server: IBM WebSphere Application Server/8.0
2016-06-13 17:47:35,974 [ server.startup : 1] [ ] [ ] ( etier.impl.EngineStartup) INFO - Web server environment: WebSphere
2016-06-13 17:47:35,974 [ server.startup : 1] [ ] [ ] ( etier.impl.EngineStartup) INFO - Web-tier default Engine bean name: EngineBMT
2016-06-13 17:47:35,974 [ server.startup : 1] [ ] [ ] ( etier.impl.EngineStartup) INFO - Enterprise server environment: WebSphere
2016-06-13 17:47:35,974 [ server.startup : 1] [ ] [ ] ( etier.impl.EngineStartup) INFO - Enterprise-tier default Engine bean name: EngineBMT
2016-06-13 17:47:35,974 [ server.startup : 1] [ ] [ ] ( etier.impl.EngineStartup) INFO - Web to Enterprise tier delegate type: local
2016-06-13 17:47:35,974 [ server.startup : 1] [ ] [ ] ( etier.impl.EngineStartup) INFO - Now starting the PegaRULES Engine...
2016-06-13 17:47:36,168 [ server.startup : 1] [ ] [ ] ( internal.mgmt.PRNodeImpl) INFO - Using codeset version and timestamp map: {[email protected] 20:48:00.0, [email protected] 01:00:00.0}
2016-06-13 17:47:36,711 [ was0462.bc] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Generated source : file://runtime:/PRGenJava/
2016-06-13 17:47:36,711 [ was0462.bc] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Generated classes: file://runtime:/PRGenClasses/
2016-06-13 17:47:36,714 [ was0462.bc] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Web-tier real root path: /websphere/oes8i1/installedApps/mco8i/oesi_prpc_ws.ear/prwebOES.war
2016-06-13 17:47:36,714 [ was0462.bc] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Web-tier temporary path: /websphere/oes8i1/temp/oes8i1/oesi_server/oesi_prpc_ws/prwebOES.war
2016-06-13 17:47:36,714 [ was0462.bc] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - PegaRULES real root path: /websphere/oes8i1/installedApps/mco8i/oesi_prpc_ws.ear/prwebOES.war
2016-06-13 17:47:36,714 [ was0462.bc] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - PegaRULES effective root path: file://default:/
2016-06-13 17:47:36,714 [ was0462.bc] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - PegaRULES effective temp path: /oesi/was/var/temp/PegaTempDir
2016-06-13 17:47:36,714 [ was0462.bc] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Using genSourcePath: file://runtime:/PRGenJava/
2016-06-13 17:47:36,714 [ was0462.bc] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Using genClassPath (database): pegajdbc://812571327:1/
2016-06-13 17:47:36,714 [ was0462.bc] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Using genClassPath (files): file://runtime:/PRGenClasses/
2016-06-13 17:47:36,714 [ was0462.bc] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Using external classes in: <not using external classes>
2016-06-13 17:47:36,714 [ was0462.bc] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Using external jars in: <not using external jars>
2016-06-13 17:47:36,898 [ was0462.bc] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - for resource: javax/servlet/http/HttpServletRequest.class, converted bundleresrouce URL (bundleresource://188.fwk-394993449/javax/servlet/http/HttpServletRequest.class) to resolved URL: jar:file:/websphere/product/AppServer/8.0/plugins/javax.j2ee.servlet.jar!/javax/servlet/http/HttpServletRequest.class
2016-06-13 17:47:36,898 [ was0462.bc] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - for resource: javax/servlet/jsp/PageContext.class, converted bundleresrouce URL (bundleresource://183.fwk-394993449/javax/servlet/jsp/PageContext.class) to resolved URL: jar:file:/websphere/product/AppServer/8.0/plugins/javax.j2ee.jsp.jar!/javax/servlet/jsp/PageContext.class
2016-06-13 17:47:36,899 [ was0462.bc] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - for resource: javax/ejb/EJBHome.class, converted bundleresrouce URL (bundleresource://172.fwk-394993449/javax/ejb/EJBHome.class) to resolved URL: jar:file:/websphere/product/AppServer/8.0/plugins/javax.j2ee.ejb.jar!/javax/ejb/EJBHome.class
2016-06-13 17:47:36,899 [ was0462.bc] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - for resource: javax/jms/Queue.class, converted bundleresrouce URL (bundleresource://181.fwk-394993449/javax/jms/Queue.class) to resolved URL: jar:file:/websphere/product/AppServer/8.0/plugins/javax.j2ee.jms.jar!/javax/jms/Queue.class
2016-06-13 17:47:36,899 [ was0462.bc] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Servlet classes: /websphere/product/AppServer/8.0/plugins/javax.j2ee.servlet.jar (javax.j2ee.servlet; singleton:=true : 7.0.0)
2016-06-13 17:47:36,900 [ was0462.bc] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - JSP classes: /websphere/product/AppServer/8.0/plugins/javax.j2ee.jsp.jar (javax.j2ee.jsp; singleton:=true : 2.2)
2016-06-13 17:47:36,900 [ was0462.bc] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - EJB classes: /websphere/product/AppServer/8.0/plugins/javax.j2ee.ejb.jar (javax.j2ee.ejb; singleton:=true : 8.0.0)
2016-06-13 17:47:36,900 [ was0462.bc] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - JMS classes: /websphere/product/AppServer/8.0/plugins/javax.j2ee.jms.jar (javax.j2ee.jms; singleton:=true : 7.0.0)
2016-06-13 17:47:37,154 [ was0462.bc] [ ] [ ] (rnal.access.CacheContainerImpl) INFO - Using the Dynamic Cache Probation Policy - cache after 2 accesses AND with a blob increment of 102400.
2016-06-13 17:47:37,376 [ was0462.bc] [ ] [ ] (pcentric.RACacheAppCentricImpl) INFO - Prune threshold is 10000
2016-06-13 17:47:37,376 [ was0462.bc] [ ] [ ] (pcentric.RACacheAppCentricImpl) INFO - mFUAReusableEnabled = true, mConstructorReuseEnabled = false, mFUAReusableEnabledStream = true
2016-06-13 17:47:37,456 [ was0462.bc] [ ] [ ] (pcentric.RACacheAppCentricImpl) INFO - Using RACacheAppCentricImpl for assembly cache implementations
2016-06-13 17:47:37,456 [ was0462.bc] [ ] [ ] (pcentric.RACacheAppCentricImpl) INFO - Assembly avoidance will use branch ruleset optimization
2016-06-13 17:47:37,457 [ was0462.bc] [ ] [ ] (nal.cache.AssemblyCacheWrapper) INFO - Assembly Cache Wrapper: configuredCacheType = AC
2016-06-13 17:47:37,487 [ was0462.bc] [ ] [ ] ( internal.mgmt.PRNodeImpl) INFO - MBean registered via PRNodeImpl: ba551f221234ed4de8a6937cbb25bcbe
2016-06-13 17:47:37,498 [ was0462.bc] [ ] [ ] ( priv.management.MBeanSecurity) INFO - The following MBean security configuration has been applied:
2016-06-13 17:47:37,498 [ was0462.bc] [ ] [ ] ( priv.management.MBeanSecurity) INFO - deny.RequestorManagement.Clipboard=true
2016-06-13 17:47:37,498 [ was0462.bc] [ ] [ ] ( priv.management.MBeanSecurity) INFO - deny.RequestorManagement.RequestorDetails=true
2016-06-13 17:47:37,498 [ was0462.bc] [ ] [ ] ( priv.management.MBeanSecurity) INFO - deny.DatabaseManagement.DatabaseConnectionDetails=true
2016-06-13 17:47:37,675 [ was0462.bc] [ ] [ ] (riv.management.MBeanManagement) INFO - MBean Management (Enterprise) initialized for WebSphere
2016-06-13 17:47:37,734 [ was0462.bc] [ ] [ ] ( internal.mgmt.PRNodeImpl) INFO - Asynchronous processing will execute via the com.ibm.websphere.asynchbeans.WorkManager interface.
2016-06-13 17:47:37,767 [ was0462.bc] [ ] [ ] ( internal.mgmt.PRRequestorImpl) INFO - RecordWorkInProgress is not enabled
2016-06-13 17:47:38,146 [ was0462.bc] [ ] [ ] (orization.SessionAuthorization) INFO - RSL Update Behavior: Eager
2016-06-13 17:47:38,327 [ was0462.bc] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Bytes input per interaction warning threshold: 50M
2016-06-13 17:47:38,333 [ was0462.bc] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - ClassMap using multi-tenant environment: false
2016-06-13 17:47:38,333 [ was0462.bc] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - Reading the class group definitions
2016-06-13 17:47:38,421 [ was0462.bc] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - Read 17 class group definitions
2016-06-13 17:47:38,421 [ was0462.bc] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - Reading the class definitions
2016-06-13 17:48:02,354 [ was0462.bc] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - Read 12915 class definitions
2016-06-13 17:48:05,039 [ was0462.bc] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Database product: Oracle
2016-06-13 17:48:05,039 [ was0462.bc] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Database version: Oracle Database 11g Enterprise Edition Release 11.2.0.4.0 - 64bit Production
With the Partitioning option
2016-06-13 17:48:05,039 [ was0462.bc] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Driver: Oracle JDBC driver
2016-06-13 17:48:05,039 [ was0462.bc] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Driver version: 11.2.0.1.0
2016-06-13 17:48:05,039 [ was0462.bc] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Version of JDBC supported by driver: 11.2
2016-06-13 17:48:18,139 [ was0462.bc] [ ] [ ] (pboard.StorageStreamCommonImpl) INFO - Storage stream version is 7
2016-06-13 17:48:21,430 [ was0462.bc] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load instance filter ..starting
2016-06-13 17:48:21,430 [ was0462.bc] [ STANDARD] [ ] (al.access.InstanceExistsFilter) INFO - Scanning instance ids
2016-06-13 17:48:54,228 [ was0462.bc] [ STANDARD] [ ] (al.access.InstanceExistsFilter) INFO - Added 116164 entries to the instance exists filter in 32.79800 seconds with a false positive rate of 0.0010
2016-06-13 17:48:54,228 [ was0462.bc] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load instance filter ..done
2016-06-13 17:48:54,248 [ was0462.bc] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load getDeclarativeCommon ..starting
2016-06-13 17:48:54,248 [ was0462.bc] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load getDeclarativeCommon ..done
2016-06-13 17:48:54,249 [ was0462.bc] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load Declarative Page Definition Cache ..starting
2016-06-13 17:49:05,781 [ was0462.bc] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load Declarative Page Definition Cache ..done
2016-06-13 17:49:09,356 [ was0462.bc] [ STANDARD] [ ] ( internal.mgmt.PRNodeImpl) INFO - Node Identification: "was0462.bc OES_ITT 2016-06-13 15:47:36.691 GMT"; Node Id: ba551f221234ed4de8a6937cbb25bcbe
2016-06-13 17:49:09,365 [ was0462.bc] [ STANDARD] [ ] ( internal.mgmt.PRNodeImpl) INFO - Starts joining cluster
2016-06-13 17:49:10,919 [ was0462.bc] [ STANDARD] [ ] ( internal.mgmt.PRNodeImpl) INFO - Ends joining cluster
2016-06-13 17:49:10,919 [ was0462.bc] [ STANDARD] [ ] ( internal.mgmt.PRNodeImpl) INFO - Clustering technology: hazelcast
2016-06-13 17:49:10,956 [ was0462.bc] [ STANDARD] [ ] ( internal.mgmt.PRNodeImpl) INFO - Starts Initializing Search Infrastructure
2016-06-13 17:49:59,633 [ was0462.bc] [ STANDARD] [ ] (.internal.PRSearchProviderImpl) INFO - Initialized full text search functionality for this node.
2016-06-13 17:49:59,633 [ was0462.bc] [ STANDARD] [ ] ( internal.mgmt.PRNodeImpl) INFO - Ends Initializing Search Infrastructure
2016-06-13 17:49:59,702 [ was0462.bc] [ STANDARD] [ ] ( internal.mgmt.PRNodeImpl) INFO - Checking Cluster consistency
2016-06-13 17:50:06,825 [069a255833e2.event-4] [ STANDARD] [ ] (nternal.PRClusterHazelcastImpl) INFO - Cluster membership changed; new member joined:
2016-06-13 17:50:06,825 [069a255833e2.event-4] [ STANDARD] [ ] (nternal.PRClusterHazelcastImpl) INFO - Member '74c5d209-c081-4bbe-add2-3f05f18e548bwas0462.bc/10.120.93.15:5701' <== this node
2016-06-13 17:50:06,825 [069a255833e2.event-4] [ STANDARD] [ ] (nternal.PRClusterHazelcastImpl) INFO - Member '127906b5-a4fa-473e-b7d9-bd03c7112a60was0462.bc/10.120.93.15:5702'
2016-06-13 17:50:09,878 [69a255833e2.event-10] [ STANDARD] [ ] (nternal.PRClusterHazelcastImpl) INFO - Cluster membership changed; member exited:
2016-06-13 17:50:09,878 [69a255833e2.event-10] [ STANDARD] [ ] (nternal.PRClusterHazelcastImpl) INFO - Member '127906b5-a4fa-473e-b7d9-bd03c7112a60was0462.bc/10.120.93.15:5702' <== this node
2016-06-13 17:50:09,978 [ was0462.bc] [ STANDARD] [ ] ( internal.mgmt.PRNodeImpl) INFO - PegaRULES extract marker file not found; resetting local caches
2016-06-13 17:50:09,978 [ was0462.bc] [ STANDARD] [ ] ( internal.mgmt.PRNodeImpl) INFO - Deleting old web content, cached lists and rules.
2016-06-13 17:50:10,082 [ was0462.bc] [ STANDARD] [ ] ( internal.mgmt.PRNodeImpl) INFO - Preparing Rule-Utility-Library definitions for use...
2016-06-13 17:52:08,864 [ was0462.bc] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load pegaConclusions ..starting
2016-06-13 17:52:12,754 [ was0462.bc] [ STANDARD] [ ] (dictionary.ConclusionCacheImpl) INFO - Starting conclusion pre-load...
2016-06-13 17:52:52,191 [ was0462.bc] [ STANDARD] [ ] (dictionary.ConclusionCacheImpl) INFO - Pre-Loaded 61071 conclusions
2016-06-13 17:52:52,192 [ was0462.bc] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load pegaConclusions ..done
2016-06-13 17:52:52,195 [ was0462.bc] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load global declarative classes ..starting
2016-06-13 17:52:52,195 [ was0462.bc] [ STANDARD] [ ] (bi.DeclarativeCacheManagerImpl) INFO - Starting global declarative cache pre-load...
2016-06-13 17:53:08,812 [ was0462.bc] [ STANDARD] [ ] (bi.DeclarativeCacheManagerImpl) INFO - Loaded 3868 global declarative cache instances
2016-06-13 17:53:08,812 [ was0462.bc] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load global declarative classes ..done
2016-06-13 17:53:17,508 [ was0462.bc] [ STANDARD] [ ] (c.DependentRuleSetListPoolImpl) INFO - Loaded 4026 ruleset dependencies
2016-06-13 17:53:17,511 [ was0462.bc] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load reloadCache ..starting
2016-06-13 17:53:17,512 [ was0462.bc] [ STANDARD] [ ] (pcentric.RACacheAppCentricImpl) INFO - Start AppCentric reloadCache processing for node ba551f221234ed4de8a6937cbb25bcbe. Maximum age in hours for Usage data is 96. Maximum rows to load is 14400
2016-06-13 17:54:18,907 [ was0462.bc] [ STANDARD] [ ] (pcentric.RACacheAppCentricImpl) INFO - End of reload processing, loaded 9901 rows, elapsed time is 61396 milliseconds.
2016-06-13 17:54:18,907 [ was0462.bc] [ STANDARD] [ ] (pcentric.RACacheAppCentricImpl) INFO - reload added 1828 assembledClasses 9901 shortcuts.
2016-06-13 17:54:18,907 [ was0462.bc] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load reloadCache ..done
2016-06-13 17:54:19,010 [ was0462.bc] [ STANDARD] [ ] (ternal.vtable.VirtualTableImpl) INFO - Virtual Table Preload Starting...
2016-06-13 17:54:28,872 [ was0462.bc] [ STANDARD] [ ] (ternal.vtable.VirtualTableImpl) INFO - ...Finished. Preloaded 11.8MB for 48946 rules in 9861 ms
2016-06-13 17:54:31,015 [ was0462.bc] [ STANDARD] [ ] (al.async.AsyncServicesExecutor) INFO - PegaRULES Async service executor initialized in e-tier.
2016-06-13 17:54:31,045 [ was0462.bc] [ STANDARD] [ ] (nal.async.AsyncServicesManager) INFO - AsyncServicesManager initialized for node.
2016-06-13 17:54:31,060 [ was0462.bc] [ STANDARD] [ ] (l.access.RuleCandidateIterator) INFO - Single candidate rule resolution optimization is enabled
2016-06-13 17:54:35,584 [ was0462.bc] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - Awaiting for StartupTasks (parallel cache loading to finish)...
2016-06-13 17:54:35,584 [ was0462.bc] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - All registered 'StartupTasks' (parallel cache loading) have finished.
2016-06-13 17:54:35,584 [ was0462.bc] [ STANDARD] [ ] ( internal.async.Agent) INFO - Agents will be executed via the enterprise tier.
2016-06-13 17:54:35,634 [ was0462.bc] [ STANDARD] [ ] (ternal.async.PassivationDaemon) INFO - PegaRULES PassivationDaemon initialized in e-tier.
2016-06-13 17:54:40,098 [ was0462.bc] [ STANDARD] [ ] ( etier.impl.EngineStartup) INFO - Product type: Standard
2016-06-13 17:54:41,595 [ was0462.bc] [ STANDARD] [ ] ( etier.impl.EngineStartup) INFO - PegaRULES engine successfully started. TimeZone: Europe/Brussels AESPerfStatMode: PUSH Server: was0462.bc System: OES_ITT Description: was0462.bc OES_ITT 2016-03-17 14:12:08.891 GMT URL: http://was0462.bc:17722/prwebOES/PRSOAPServlet
2016-06-13 17:54:41,596 [ was0462.bc] [ STANDARD] [ ] (ervlet.WebAppLifeCycleListener) INFO - MBean registered via WebAppLifeCycle: ba551f221234ed4de8a6937cbb25bcbe
2016-06-13 17:54:41,620 [ was0462.bc] [ STANDARD] [ ] (riv.management.MBeanManagement) INFO - MBean Management (Web) initialized for WebSphere
2016-06-13 17:54:41,654 [ was0462.bc] [ STANDARD] [ ] (ervlet.WebAppLifeCycleListener) INFO - Web Tier initialization is complete.
2016-06-13 17:54:48,409 [.PRPCWorkManager : 1] [ STANDARD] [Implementation:01.27] (nector.Rule_Connect_JMS.Action) ERROR Rule-Connect-JMS.BGC-Int-ServiceController-OES.SendOESResponse OESIntUser - JNDI lookup of connection factory '' failed: javax.naming.ConfigurationException: Malformed provider URL ""
at com.ibm.ws.naming.util.WsnInitCtxFactory.parseBootstrapUrl(WsnInitCtxFactory.java:1837)
at com.ibm.ws.naming.util.WsnInitCtxFactory.getInitialContextInternal(WsnInitCtxFactory.java:509)
at com.ibm.ws.naming.util.WsnInitCtx.getContext(WsnInitCtx.java:128)
at com.ibm.ws.naming.util.WsnInitCtx.getContextIfNull(WsnInitCtx.java:765)
at com.ibm.ws.naming.util.WsnInitCtx.lookup(WsnInitCtx.java:164)
at com.ibm.ws.naming.util.WsnInitCtx.lookup(WsnInitCtx.java:179)
at org.apache.aries.jndi.DelegateContext.lookup(DelegateContext.java:161)
at javax.naming.InitialContext.lookup(InitialContext.java:436)
at com.pegarules.generated.activity.ra_action_invokejmsconnector_1312bbe05af1824b176aa2dd86b5d68e.step1_circum0(ra_action_invokejmsconnector_1312bbe05af1824b176aa2dd86b5d68e.java:661)
at com.pegarules.generated.activity.ra_action_invokejmsconnector_1312bbe05af1824b176aa2dd86b5d68e.perform(ra_action_invokejmsconnector_1312bbe05af1824b176aa2dd86b5d68e.java:69)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3500)
at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:10521)
at com.pegarules.generated.activity.ra_action_invoke_a89c88dc2333f1fdb308dd3a64dd4f5a.step4_circum0(ra_action_invoke_a89c88dc2333f1fdb308dd3a64dd4f5a.java:366)
at com.pegarules.generated.activity.ra_action_invoke_a89c88dc2333f1fdb308dd3a64dd4f5a.perform(ra_action_invoke_a89c88dc2333f1fdb308dd3a64dd4f5a.java:120)
at com.pegarules.generated.activity.ra_action_childinvoke_34be484f442477bb0a926c4384d3a9e8.step4_circum0(ra_action_childinvoke_34be484f442477bb0a926c4384d3a9e8.java:393)
at com.pegarules.generated.activity.ra_action_childinvoke_34be484f442477bb0a926c4384d3a9e8.perform(ra_action_childinvoke_34be484f442477bb0a926c4384d3a9e8.java:126)
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:646)
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivities(ThreadRunner.java:572)
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivities(PRThreadImpl.java:453)
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.executeBatchTask(QueueProcessor.java:257)
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.execute(QueueProcessor.java:320)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:945)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1259)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1008)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:901)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:670)
at com.pega.pegarules.session.internal.async.Agent.runBatchTask(Agent.java:815)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.AsyncServant.processAsyncTask(AsyncServant.java:230)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.AsyncServant.invoke(AsyncServant.java:167)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:315)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:263)
at com.pega.pegarules.session.internal.engineinterface.etier.ejb.EngineBean.invokeEngine(EngineBean.java:225)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:60)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37)
at java.lang.reflect.Method.invoke(Method.java:611)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:367)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:408)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingException(AppServerBridgeToPega.java:245)
at com.pega.pegarules.internal.etier.ejb.EngineBeanBoot.invokeEngine(EngineBeanBoot.java:168)
at com.pega.pegarules.internal.etier.interfaces.EJSLocalStatelessEngineBMT_f2439d86.invokeEngine(Unknown Source)
at com.pega.pegarules.session.internal.engineinterface.etier.mdb.PRAsync.processRequest(PRAsync.java:155)
at com.pega.pegarules.session.internal.engineinterface.etier.asynchbeans.AsyncTask.run(AsyncTask.java:64)
at com.pega.pegarules.session.internal.engineinterface.etier.asynchbeans.RunnableWrapper.run(RunnableWrapper.java:71)
at com.ibm.ws.asynchbeans.J2EEContext$RunProxy.run(J2EEContext.java:271)
at java.security.AccessController.doPrivileged(AccessController.java:399)
at com.ibm.ws.asynchbeans.J2EEContext.run(J2EEContext.java:797)
at com.ibm.ws.asynchbeans.WorkWithExecutionContextImpl.go(WorkWithExecutionContextImpl.java:222)
at com.ibm.ws.asynchbeans.ABWorkItemImpl.run(ABWorkItemImpl.java:206)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1731)
2016-06-13 17:54:48,409 [.PRPCWorkManager : 0] [ STANDARD] [Implementation:01.27] (nector.Rule_Connect_JMS.Action) ERROR Rule-Connect-JMS.BGC-Int-ServiceController-OES.SendOESResponse OESIntUser - JNDI lookup of connection factory '' failed: javax.naming.ConfigurationException: Malformed provider URL ""
2016-06-13 17:54:48,412 [.PRPCWorkManager : 0] [ STANDARD] [Implementation:01.27] ( internal.mgmt.Executable) ERROR OESIntUser - Exception
com.pega.pegarules.pub.services.ResourceUnavailableException: JNDI lookup of connection factory '' failed: javax.naming.ConfigurationException: Malformed provider URL ""
at com.pegarules.generated.activity.ra_action_invokejmsconnector_1312bbe05af1824b176aa2dd86b5d68e.step1_circum0(ra_action_invokejmsconnector_1312bbe05af1824b176aa2dd86b5d68e.java:692)
Caused by:
... 44 more
2016-06-13 17:54:48,413 [.PRPCWorkManager : 0] [ STANDARD] [Implementation:01.27] ( internal.mgmt.Executable) ERROR OESIntUser - Exception
Caused by:
... 44 more
2016-06-13 17:54:48,413 [.PRPCWorkManager : 1] [ STANDARD] [Implementation:01.27] ( internal.mgmt.Executable) ERROR OESIntUser - Exception
Caused by:
... 44 more
2016-06-13 17:54:48,414 [.PRPCWorkManager : 1] [ STANDARD] [Implementation:01.27] ( internal.mgmt.Executable) ERROR OESIntUser - Exception
Caused by:
... 44 more
2016-06-13 17:54:48,414 [.PRPCWorkManager : 0] [ STANDARD] [Implementation:01.27] (ernal.async.BatchRequestorTask) ERROR OESIntUser - Batch activity "Rule-Connect-JMS.ChildInvoke" threw:
com.pega.pegarules.pub.PRRuntimeError: PRRuntimeError
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:712)
Caused by:
com.pega.pegarules.pub.context.PRAbandonProcessingException: PRRuntimeError
at com.pega.pegarules.session.internal.mgmt.Executable.activityStepProlog(Executable.java:1197)
at com.pegarules.generated.activity.ra_action_childinvoke_34be484f442477bb0a926c4384d3a9e8.step5_circum0(ra_action_childinvoke_34be484f442477bb0a926c4384d3a9e8.java:428)
at com.pegarules.generated.activity.ra_action_childinvoke_34be484f442477bb0a926c4384d3a9e8.perform(ra_action_childinvoke_34be484f442477bb0a926c4384d3a9e8.java:144)
... 34 more
2016-06-13 17:54:48,414 [.PRPCWorkManager : 1] [ STANDARD] [Implementation:01.27] (ernal.async.BatchRequestorTask) ERROR OESIntUser - Batch activity "Rule-Connect-JMS.ChildInvoke" threw:
Caused by:
... 34 more
2016-06-13 17:55:35,327 [.PRPCWorkManager : 2] [ STANDARD] [ ] ( services.file.FileListener) DEBUG File.BarUnbarListener|initialize OESIntUser - Established requestor with lock: AC96B247526A1708D3EB67024805FB6D2
2016-06-13 17:55:35,327 [.PRPCWorkManager : 2] [ STANDARD] [ ] ( services.file.FileListener) DEBUG File.BarUnbarListener|initialize OESIntUser - Established requestor for initialization [AC96B247526A1708D3EB67024805FB6D2].
2016-06-13 17:55:35,342 [.PRPCWorkManager : 2] [ STANDARD] [ ] ( fs.resadaptor.RAFile) INFO File.BarUnbarListener|initialize OESIntUser - RAFile will use File System
2016-06-13 17:55:35,449 [.PRPCWorkManager : 3] [ STANDARD] [ ] ( services.file.FileListener) DEBUG File.BEAFileListener|initialize OESIntUser - Established requestor with lock: AE8F48ABB1A789793BFBE5325AFDEA681
2016-06-13 17:55:35,449 [.PRPCWorkManager : 3] [ STANDARD] [ ] ( services.file.FileListener) DEBUG File.BEAFileListener|initialize OESIntUser - Established requestor for initialization [AE8F48ABB1A789793BFBE5325AFDEA681].
2016-06-13 17:55:35,525 [.PRPCWorkManager : 4] [ STANDARD] [ ] ( services.file.FileListener) DEBUG File.DIMSUpdateInfo|initialize OESIntUser - Established requestor with lock: A2F22C1C0EA91BB38651E4034299F4F4E
2016-06-13 17:55:35,525 [.PRPCWorkManager : 4] [ STANDARD] [ ] ( services.file.FileListener) DEBUG File.DIMSUpdateInfo|initialize OESIntUser - Established requestor for initialization [A2F22C1C0EA91BB38651E4034299F4F4E].
2016-06-13 17:55:35,587 [.PRPCWorkManager : 5] [ STANDARD] [ ] ( services.file.FileListener) DEBUG File.SuspendResumeAndFDListener|initialize OESIntUser - Established requestor with lock: AF9D04C2E07D10D791A2029E9F1C3EA1A
2016-06-13 17:55:35,587 [.PRPCWorkManager : 5] [ STANDARD] [ ] ( services.file.FileListener) DEBUG File.SuspendResumeAndFDListener|initialize OESIntUser - Established requestor for initialization [AF9D04C2E07D10D791A2029E9F1C3EA1A].
2016-06-13 17:55:36,075 [.PRPCWorkManager : 2] [ STANDARD] [ ] ( services.file.FileListener) ERROR File.BarUnbarListener OESIntUser - Unexpected exception caught during processing.
java.lang.Exception: [/websphere/oes8i1] does not exist.
at com.pega.pegarules.integration.engine.internal.services.file.FileListener.initialize(FileListener.java:1803)
at com.pega.pegarules.integration.engine.internal.services.file.FileListener.run_(FileListener.java:1878)
at com.pega.pegarules.integration.engine.internal.services.listener.ServiceListenerBaseImpl.run(ServiceListenerBaseImpl.java:453)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.AsyncServant.processAsyncTask(AsyncServant.java:213)
at sun.reflect.GeneratedMethodAccessor67.invoke(Unknown Source)
2016-06-13 17:55:36,075 [.PRPCWorkManager : 3] [ STANDARD] [ ] ( services.file.FileListener) ERROR File.BEAFileListener OESIntUser - Unexpected exception caught during processing.
2016-06-13 17:55:36,075 [.PRPCWorkManager : 4] [ STANDARD] [ ] ( services.file.FileListener) ERROR File.DIMSUpdateInfo OESIntUser - Unexpected exception caught during processing.
2016-06-13 17:55:36,075 [.PRPCWorkManager : 3] [ ] [ ] ( etier.impl.EngineImpl) ERROR - invokeEngine: ThreadContainer not null on exit -- clearing.
2016-06-13 17:55:36,076 [.PRPCWorkManager : 4] [ ] [ ] ( etier.impl.EngineImpl) ERROR - invokeEngine: ThreadContainer not null on exit -- clearing.
2016-06-13 17:55:36,076 [.PRPCWorkManager : 2] [ ] [ ] ( etier.impl.EngineImpl) ERROR - invokeEngine: ThreadContainer not null on exit -- clearing.
2016-06-13 17:55:36,076 [.PRPCWorkManager : 5] [ STANDARD] [ ] ( services.file.FileListener) ERROR File.SuspendResumeAndFDListener OESIntUser - Unexpected exception caught during processing.
2016-06-13 17:55:36,076 [.PRPCWorkManager : 5] [ ] [ ] ( etier.impl.EngineImpl) ERROR - invokeEngine: ThreadContainer not null on exit -- clearing.
2016-06-13 17:56:06,334 [ WebContainer : 5] [OpenPortal] [Implementation:01.27] (Search.Data_Find_Search.Action) ERROR oes8i1.web.bc|10.111.35.232 id810890 - Search request failed. Query: [*declare_*], Index [RULE]
2016-06-13 17:56:10,622 [ WebContainer : 5] [OpenPortal] [Implementation:01.27] (Search.Data_Find_Search.Action) ERROR oes8i1.web.bc|10.111.35.232 id810890 - Search request failed. Query: [*declare_*], Index [RULE]
2016-06-13 17:56:42,112 [ WebContainer : 3] [dalProcess] [Implementation:01.27] (rnal.mgmt.InitialConfiguration) INFO oes8i1.web.bc|10.119.130.38 id844152 - for resource: javax/servlet/http/HttpServletRequest.class, converted bundleresrouce URL (bundleresource://188.fwk-394993449/javax/servlet/http/HttpServletRequest.class) to resolved URL: jar:file:/websphere/product/AppServer/8.0/plugins/javax.j2ee.servlet.jar!/javax/servlet/http/HttpServletRequest.class
2016-06-13 17:56:42,112 [ WebContainer : 3] [dalProcess] [Implementation:01.27] (rnal.mgmt.InitialConfiguration) INFO oes8i1.web.bc|10.119.130.38 id844152 - for resource: javax/servlet/jsp/PageContext.class, converted bundleresrouce URL (bundleresource://183.fwk-394993449/javax/servlet/jsp/PageContext.class) to resolved URL: jar:file:/websphere/product/AppServer/8.0/plugins/javax.j2ee.jsp.jar!/javax/servlet/jsp/PageContext.class
2016-06-13 17:56:42,113 [ WebContainer : 3] [dalProcess] [Implementation:01.27] (rnal.mgmt.InitialConfiguration) INFO oes8i1.web.bc|10.119.130.38 id844152 - for resource: javax/ejb/EJBHome.class, converted bundleresrouce URL (bundleresource://172.fwk-394993449/javax/ejb/EJBHome.class) to resolved URL: jar:file:/websphere/product/AppServer/8.0/plugins/javax.j2ee.ejb.jar!/javax/ejb/EJBHome.class
2016-06-13 17:56:42,113 [ WebContainer : 3] [dalProcess] [Implementation:01.27] (rnal.mgmt.InitialConfiguration) INFO oes8i1.web.bc|10.119.130.38 id844152 - for resource: javax/jms/Queue.class, converted bundleresrouce URL (bundleresource://181.fwk-394993449/javax/jms/Queue.class) to resolved URL: jar:file:/websphere/product/AppServer/8.0/plugins/javax.j2ee.jms.jar!/javax/jms/Queue.class
2016-06-13 17:56:42,113 [ WebContainer : 3] [dalProcess] [Implementation:01.27] (rnal.mgmt.InitialConfiguration) INFO oes8i1.web.bc|10.119.130.38 id844152 - Servlet classes: /websphere/product/AppServer/8.0/plugins/javax.j2ee.servlet.jar (javax.j2ee.servlet; singleton:=true : 7.0.0)
2016-06-13 17:56:42,113 [ WebContainer : 3] [dalProcess] [Implementation:01.27] (rnal.mgmt.InitialConfiguration) INFO oes8i1.web.bc|10.119.130.38 id844152 - JSP classes: /websphere/product/AppServer/8.0/plugins/javax.j2ee.jsp.jar (javax.j2ee.jsp; singleton:=true : 2.2)
2016-06-13 17:56:42,113 [ WebContainer : 3] [dalProcess] [Implementation:01.27] (rnal.mgmt.InitialConfiguration) INFO oes8i1.web.bc|10.119.130.38 id844152 - EJB classes: /websphere/product/AppServer/8.0/plugins/javax.j2ee.ejb.jar (javax.j2ee.ejb; singleton:=true : 8.0.0)
2016-06-13 17:56:42,113 [ WebContainer : 3] [dalProcess] [Implementation:01.27] (rnal.mgmt.InitialConfiguration) INFO oes8i1.web.bc|10.119.130.38 id844152 - JMS classes: /websphere/product/AppServer/8.0/plugins/javax.j2ee.jms.jar (javax.j2ee.jms; singleton:=true : 7.0.0)
2016-06-13 17:56:49,029 [ WebContainer : 2] [ STANDARD] [Implementation:01.27] (BGC_Data_CachingDetails.Action) INFO oes8i1.web.bc|10.111.35.232 id810890 -
2016-06-13 17:57:23,667 [.PRPCWorkManager : 6] [ STANDARD] [Implementation:01.27] (nector.Rule_Connect_JMS.Action) ERROR Rule-Connect-JMS.BGC-Int-ServiceController-OES.SendOESResponse OESIntUser - JNDI lookup of connection factory '' failed: javax.naming.ConfigurationException: Malformed provider URL ""
2016-06-13 17:57:23,668 [.PRPCWorkManager : 6] [ STANDARD] [Implementation:01.27] ( internal.mgmt.Executable) ERROR OESIntUser - Exception
Caused by:
... 43 more
2016-06-13 17:57:23,669 [.PRPCWorkManager : 6] [ STANDARD] [Implementation:01.27] ( internal.mgmt.Executable) ERROR OESIntUser - Exception
Caused by:
... 43 more
PEG
I could see below error in the stacktrace. Please verify whether access has been there for the folder(/websphere/oes8i1). Click Test Connection in File Listener data instance.
Capgemini
Clicked on Test Connection and its working fine.
This directory is existing on server as well.
Is this directory websphere/oes8i1 getting re-created during server startup?
Capgemini
NO Arvind, its there all the time.
Hi Vishal, Could you please increase the File Listener polling interval to a higher value (say 900 seconds) and test the behavior?
Capgemini
This FILE LISTENER issue is coming only on one environment.
Rest all the environments its working fine.
Checked all the configurations and its same that's why running out of ideas what has happened different here.
Hi Vishal,
Can you try increasing concurrent thread value to more than 1 and see if Listeners starts automatically during server startup?
Capgemini
Hi Arvind,
I will talk to Operations team to make these changes.
In the meantime I am not aware the usage of concurrent thread in file listener.
Can you please provide details of the usage of concurrent thread?
Vishal
HI Vishal,
Please find below exert from Pega Help about concurrent thread parameter in File Listener:
"Enter 1 or a small positive integer to determine the number of threads per server node this listener requestor creates when it starts. Each thread operates on a single file; multithreading has no benefit unless multiple files are available at the same time for processing.
If the node on which this listener runs has available JVM memory and CPU cycles, and multiple files are available for processing, use of two to five threads can increase throughput."
Capgemini
We are getting single file at a time. Also processing is not a concern here.
Only point is whwn server starts file listener doesn't start automatically
Hi Vishal,
Ensure that you either have the following prconfig/DSS set to "true"
1. Pega-Engine • prconfig/initServices/initFile/default*Pega-ProcessCommander
2. <env name="initServices/initFile" value="true" />
Capgemini
Vishal,
Look at the resolution under PDN artcile - https://community.pega.com/support/support-articles/filelistener-not-processing-files
Capgemini
Dears,
I found the issue:
let me share some more details. We have arum 9 JMS MDB listeners as well.
We changed the initial state of all the JMS MDB Listeners @ was console and restarted the server.
All file listeners came up gracefully.
Then we changed the initial state of JMS MDB listeners one by one.
8 out 9 JMS MDB listeners didn't give any issue and file listeners got started along with JMS MDB listeners.
Only 1 JMS MDB listener is causing file listener not to start along with server restart.
Connection between JMS MDB listener & File listener is they are sharing common data page (declare page).
This 9th JMS MDB listener while server restart:
- Not letting declare page (data page) loading properly
- Due to which file listener is not getting its file path and not coming up
Now the issue is why this JMS MDB listener is making data page not to load properly while restart.
When we load this page manually its working fine.
Vishal
Just for clarity - what is the scope of your Data Page? (Thread/Requestor/Node)
Capgemini
PEG
What happens if you switch the scope of datapage to thread or requestor? Same behavior exists?
Capgemini
In production we have a clustered environment of 16 servers.
Its better to keep it at node level.
Let me know otherwise.
Capgemini
Guys i need help ...my Go Live is close..
Plz help
Updated: 26 Jun 2016 4:49 EDT
Hi Vishal, Good morning!
>>> Not letting declare page (data page) loading properly..
- can we enable loggers and learn why this Data Page alone has the problem?
- com.pega.pegarules.exec.internal.declare.infengine.pages.DeclarativePageDirectoryImpl (please turn off after collecting the logs)
- as part of analysis, would it be convincing to comment/hard code the logic applied in that data page?
- or oLog.infoForced("debug: " + myStepPage.getXML());
- not sure but it could be a race condition where data page is failing to load.
- as the data page is defined read-only...
- could we confirm no writes onto this page?
- or as Ganga said please perform a quick test by changing it to editable/requester...?
Please share your thoughts/comments, Thank you!
psahukaru
Capgemini
HI Phani,
file listener issue already tested. the only issue is Declare page not loading correctly which is causing the file listener to fail.
I will put these logging which you suggested for DECLARE PAGE & check.
Vishal
Capgemini
HI Phani,
This is the first error which is coming after server restart ...and after that load of declare page fails....
2016-06-27 14:00:27,859 [.PRPCWorkManager : 0] [ STANDARD] [Implementation:01.27] (ernal.async.BatchRequestorTask) ERROR OESIntUser - Batch activity "Rule-Connect-JMS.ChildInvoke" threw:
HI Phani,
Caused by:
at com.pegarules.generated.activity.ra_action_invokejmsconnector_1312bbe05af1824b176aa2dd86b5d68e.step1_circum0(ra_action_invokejmsconnector_1312bbe05af1824b176aa2dd86b5d68e.java:224)
... 34 more
- is RULE-OBJ-ACTIVITY RULE-CONNECT-JMS INVOKEJMSCONNECTOR customized?
- can we try adding oLog statements...?
oLog.infoForced("------------------------------------------------------Debug Starts for pxRequestor page ----------------------------------------------------");
- oLog.infoForced("Requestor Name pyUserIdentifier: " + myStepPage.getString(".pyUserIdentifier"));
oLog.infoForced("Requestor Name pxUserIdentifier: " + myStepPage.getString(".pxUserIdentifier"));
oLog.infoForced("Requestor Page: " + myStepPage.getXML());
oLog.infoForced("------------------------------------------------------Debug Ends for pxRequestor page ----------------------------------------------------");
What is the data source for this data page?
Capgemini
Data source is an activity which in turn calling 4 data transforms which are having data.
Pegasystems
As mentioned in that article, there seems to be a class that if you set to DEBUG, it gives some info. Did you try that? The class is com.pega.pegarules.integration.engine.internal.services.file.FileListener . /Eric
Capgemini
Hi Eric...
I mentioned in my earlier posts...that issue is with JMS MDB listerner which is failing file listener to start..
Please have a look at my earlier posts for full details...
Issue is still there ...no fix found
Capgemini
Raised an SR for Pega...lets see.
Could you please reply with the SR number so that we can attach this PSC discussion to the SR to assist the Engineer who will receive the SR?
Thanks in advance!
Capgemini
Thank you! I've updated your post with the SR and have attached the SR to this discussion!
Upon reviewing the corresponding SR, we see that it has been resolved. SA-25865 was created as a result of the investigation. Please reference that if you have the same question.
Lochan | Online Community Moderator | Pegasystems Inc.
