SINARMASMSIGLIFE
ID
Last activity: 9 Feb 2017 5:07 EST
Pega cannot run after restart server
Why my pega server cannot start after restart server? I used, v721, JBOSS, Oracle and RedHat Linux.
In log, there's an info
[LOCAL] [564462a54e8efab83241814626c1214c] [3.4.1] Interfaces is disabled, trying to pick one address from TCP-IP config addresses: []
I has tried to truncate PR_SYS_STATUSNODES database table, based on this post https://community.pega.com/support/support-articles/hazelcast-errors-observed-log-server-startup but it still same.
Can you help me?
Alfian
***Updated by moderator: Lochan to update Categories; added SR details***
Hi Alfian,
It seems to be hazelcast not able to bind with port and IP address mentioned. Please check manually whether it is able to listen with port which is configured.
SINARMASMSIGLIFE
ID
Hi othos,
In manual, it need to open port 5701-5800 and I already open it. From a few months ago, there is not a problem for hazelcast but it happen yesterday after restart server.
Hi Alfian,
Can you please check the previous established connection is properly shutdown? Is there any process still alive using the same port. May be you can use the command ps -aef | grep port number to find out.
SINARMASMSIGLIFE
ID
Hi Othos,
I already check, there is no process at port 5701 and just made sure, I kill the port using # fuser -k 5701/tcp.
When I check table PR_SYS_STATUSNODES, and it have a column name pycleanshutdown with value is false after I tried to start pega again. Is it mean that the connection not properly shutdown?
As per my understanding, if the node is in run state it will be false and if the node is in shutdown or stopped state the value will be true
SINARMASMSIGLIFE
ID
So it means, the node is in shutdown properly. What else is need? if I must change the prconfig.xml file, what is the configuration that I need to add?
Hi Alfian,
I have analyzed your complete log file and couldn't find any other error which can point to root cause.
For cross verifying, I have shared the log with Hazelcast SME for his inputs.
Hi Alfian,
SME also confirmed that he couldn't find any other error which can point to root cause. This require additional effort to analyze. Hence, kindly request you to raise an SR for this.
SINARMASMSIGLIFE
ID
Hi Sudhish,
I have asked someone to raise SR, but I do not know when he will do it.
Thanks for your help.
Thanks for that
SINARMASMSIGLIFE
ID
Hi Sudhish,
This is the SR number SR-B30336.
Hi Alfian,
Please let us know if you do log an SR for this and its ID. That way we can track it and follow-up this discussion with the resolution.
Lochan | Community Moderator | Pegasystems Inc.
SINARMASMSIGLIFE
ID
Hi Lochan,
I'll let you know, if it already done.
Thanks.
SINARMASMSIGLIFE
ID
Hi Lochan,
Thanks and Regards,
Alfian
Thanks Alfian,
I have updated the original post above with this information. I have also added a pulse post on the SR so that these two are effectively linked.
SINARMASMSIGLIFE
ID
Everything done, I can load pega again.
The real problem is timed out when Jboss start to deploy prweb. So I change some configurations in standalone-full.xml
1. Change configuration
<property name="-Djboss.as.management.blocking.timeout" value="600"/>
to
<property name="jboss.as.management.blocking.timeout" value="10800"/>
2. Comment xml tag <deployments> and it’s contents
3. Start Jboss
4. Redeploy all apps sequentially,
- prpc_j2ee14_jboss61JBM.ear
- prsysmgmt.war
- prhelp.war
As for the real question is, how it takes a long times to deploy prpc in our system.
Thank you for your help.
Alfian
