Infosys
Last activity: 5 Dec 2017 9:23 EST
File listener source location value is not changing (Using Data Page )
We have a requirement to access shared path location(Location will be changes every day) and process CSV file at specific time. So we have used File listener rule to access shared path location using Data page in source location. Data page rule has logic to refresh shared path value for every 30 min.
here when listener starts processing the CSV file, its not changing the shared path location and its taking the path which is initially created by data page. after that its not refreshing with new location. We have set log message in data page rule to capture the shared location on file listener each run. Its not setting any logs on each run.
Can any one suggest what could be the reason for not updating data page in file listener (Source location field)?
Thanks in Advance.
