Infosys
Last activity: 6 Dec 2017 12:30 EST
Is it possible to change File listener path location using Data page rule refresh logic on each execution.
Is it possible to change File listener path location using Data page rule refresh logic?
Likes (1)
Anderson Farias -
JPMorgan Chase & Company
As of my understanding listener won't refresh the path every time when data page refreshed. At the time of starting only the path will set and to reflect the changes we have to restart the listener.
Virtusa Consulting UK
Yes. Please pass the location as a parameter using the data page.
syntax will be something like this
=pageName.propertyName .
You can populate whatever value you want to , in the datapage.
Please let me know if you need any other information.
Thanks.
Infosys
i have used Data page for source location. this rule not updating data page value dynamically and its executing every time with the location value which is generated first time. its not refreshing with new value. data page refresh logic is working properly but listener file not consuming latest data from Data page rule.
Please let us know if you have any idea on this issue?
Yes, you can use as below
=D_pagename.sourcelocation
Infosys
i have used Data page but listener rule not updating the location . this rule not updating data page value dynamically and its executing every time with the location value which is generated first time. its not refreshing with new value. data page refresh logic is working properly but listener file not consuming latest data from Data page rule.
Infosys
Hi Sudhakar,
Thanks for update. I got same response from Pega support teamalso.
How can I achieve my requirement to change source location on each refresh?
Rahul Choudhary
