Fault Tolerent URL in Connect REST Rule
From Pega Application I call an API using Connect REST. I need to know how to make connect REST Fault Tolerent. for connect JMS I give Server values in comma seperated values in jndi server profile which triggers request based on server availability. I like to know if its OOTB function for Connect REST as well?
If I give Server A, Server B in provider url path in Connect REST rule then if server A is down, will the call be made to Server B?
I'm currently testing in my POC envrionment to check but want to know if that feature is available or not.
Mak
