Great Eastern Singapore
SG
Last activity: 11 Feb 2019 7:23 EST
fault tolerant shared storage
Shared Storage Application servers require fault-tolerant shared storage in order to facilitate initiated and uninitiated shutdowns. Organizations must choose a shared storage solution and will need to implement the shared storage API to integrate with PEGA 7. PEGA 7 supports shared storage using NFS or shared disk out of the box, but these solutions are not inherently fault tolerant.
Can some one suggest what we need to use for fault tolerant shared storage?
If custom shared storage implementations are required, the following plug-in for shared storage must be used: com.pega.pegarules.pub.session.CustomPassivationMechanism
Please refer below link for more information : https://community.pega.com/sites/default/files/help_v731/engine/high-availability/architecture/eng-high-availability-shared-storage-con.htm
One more below psc link is found. Please check It also may help you
https://collaborate.pega.com/discussion/high-availability-deployment-and-shared-storage
