Test Connectivity for REST-Connect Rule - Getting 401 Error
I am getting the below error while doing a test connectivity in Connect-REST rule. We are using a HTTP endpoint url with basic authentication and able to receive response using SOAP UI.
The password contains a special character. I am not sure if it is causing an issue?
I am not sure why 401 error is receive after the System is able to connect to the removed server (please see attached screenshot). Any inputs will be helpful.
Note1: I have tried with checking and unchecking the preemptive authentication checkbox in the Auth Profile rule
Note2: I have set the logger name to "Rule_Obj_Activity.pyInvokeRESTConnector.Rule_Connect_REST.Action" and the level to DEBUG - But could not find any information in the log files.
PRPC Version - 7.2.1
