Failed to initialize the application "prpc_wls_jee4"
Hi ,
We are upgrading application from pega 6.1 to 7.2.2 . while starting application server , it is throwing below exception and not able to launch the application.
Can someone please help us here.
<Aug 11, 2017, 9:04:10,806 AM CDT> <Error> <Deployer> <BEA-149205> <Failed to initialize the application "prpc_wls_jee4" due to error weblogic.application.ModuleException: [1] The class 'com.pega.pegarules.internal.etier.interfaces.PRRA
ConnectionFactory', which is defined as [<connectionfactory-interface>] from [META-INF/ra.xml], was not found in the resource adapter archive/application.
[2] The class 'com.pega.pegarules.ra.cci.PRConnectionFactoryImpl', which is defined as [<connectionfactory-impl-class>] from [META-INF/ra.xml], could not be loaded from the resource adapter archive/application because of the following e
rror: java.lang.NoClassDefFoundError: com/pega/pegarules/internal/etier/interfaces/PRRAConnectionFactory
weblogic.application.ModuleException: [1] The class 'com.pega.pegarules.internal.etier.interfaces.PRRAConnectionFactory', which is defined as [<connectionfactory-interface>] from [META-INF/ra.xml], was not found in the resource adapter
Hi ,
at weblogic.application.internal.ExtensibleModuleWrapper.prepare(ExtensibleModuleWrapper.java:114)
at weblogic.application.internal.flow.ModuleListenerInvoker.prepare(ModuleListenerInvoker.java:100)
at weblogic.application.internal.flow.ModuleStateDriver$1.next(ModuleStateDriver.java:192)
at weblogic.application.internal.flow.ModuleStateDriver$1.next(ModuleStateDriver.java:187)
at weblogic.application.utils.StateMachineDriver.nextState(StateMachineDriver.java:45)
at weblogic.application.internal.flow.ModuleStateDriver.prepare(ModuleStateDriver.java:37)
at weblogic.application.internal.flow.DeploymentCallbackFlow.prepare(DeploymentCallbackFlow.java:77)
at weblogic.application.internal.flow.DeploymentCallbackFlow.prepare(DeploymentCallbackFlow.java:55)
at weblogic.application.internal.BaseDeployment$1.next(BaseDeployment.java:727)
at weblogic.application.internal.BaseDeployment.prepare(BaseDeployment.java:239)
at weblogic.application.internal.EarDeployment.prepare(EarDeployment.java:66)
at weblogic.application.internal.DeploymentStateChecker.prepare(DeploymentStateChecker.java:158)
at weblogic.deploy.internal.targetserver.AppContainerInvoker.prepare(AppContainerInvoker.java:65)
at weblogic.deploy.internal.targetserver.AppDeployment.prepare(AppDeployment.java:155)
at weblogic.management.deploy.internal.DeploymentAdapter$1.doPrepare(DeploymentAdapter.java:41)
at weblogic.management.deploy.internal.DeploymentAdapter.prepare(DeploymentAdapter.java:193)
at weblogic.management.deploy.internal.AppTransition$1.transitionApp(AppTransition.java:31)
at weblogic.management.deploy.internal.ConfiguredDeployments$2.doItem(ConfiguredDeployments.java:684)
at weblogic.management.deploy.internal.parallel.BucketInvoker.invoke(BucketInvoker.java:138)
at weblogic.management.deploy.internal.ConfiguredDeployments.transitionAppsParallel(ConfiguredDeployments.java:692)
at weblogic.management.deploy.internal.ConfiguredDeployments.prepare(ConfiguredDeployments.java:322)
at weblogic.management.deploy.internal.ConfiguredDeployments.deploy(ConfiguredDeployments.java:202)
at weblogic.management.deploy.internal.DeploymentServerService.resume(DeploymentServerService.java:207)
at weblogic.management.deploy.internal.DeploymentServerService.start(DeploymentServerService.java:129)
at weblogic.server.AbstractServerService.postConstruct(AbstractServerService.java:76)
at sun.reflect.GeneratedMethodAccessor99.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.glassfish.hk2.utilities.reflection.ReflectionHelper.invoke(ReflectionHelper.java:1262)
at org.jvnet.hk2.internal.ClazzCreator.postConstructMe(ClazzCreator.java:332)
at org.jvnet.hk2.internal.ClazzCreator.create(ClazzCreator.java:374)
at org.jvnet.hk2.internal.SystemDescriptor.create(SystemDescriptor.java:471)
at org.glassfish.hk2.runlevel.internal.AsyncRunLevelContext.findOrCreate(AsyncRunLevelContext.java:232)
at org.glassfish.hk2.runlevel.RunLevelContext.findOrCreate(RunLevelContext.java:85)
at org.jvnet.hk2.internal.Utilities.createService(Utilities.java:2020)
at org.jvnet.hk2.internal.ServiceHandleImpl.getService(ServiceHandleImpl.java:114)
at org.jvnet.hk2.internal.ServiceLocatorImpl.getService(ServiceLocatorImpl.java:693)
at org.jvnet.hk2.internal.ThreeThirtyResolver.resolve(ThreeThirtyResolver.java:78)
at org.jvnet.hk2.internal.ClazzCreator.resolve(ClazzCreator.java:211)
at org.jvnet.hk2.internal.ClazzCreator.resolveAllDependencies(ClazzCreator.java:234)
at org.jvnet.hk2.internal.ClazzCreator.create(ClazzCreator.java:357)
at org.jvnet.hk2.internal.ServiceHandleImpl.getService(ServiceHandleImpl.java:88)
at org.glassfish.hk2.runlevel.internal.CurrentTaskFuture$QueueRunner.oneJob(CurrentTaskFuture.java:1213)
at org.glassfish.hk2.runlevel.internal.CurrentTaskFuture$QueueRunner.run(CurrentTaskFuture.java:1144)
at weblogic.work.SelfTuningWorkManagerImpl$WorkAdapterImpl.run(SelfTuningWorkManagerImpl.java:666)
at weblogic.invocation.ComponentInvocationContextManager._runAs(ComponentInvocationContextManager.java:348)
at weblogic.invocation.ComponentInvocationContextManager.runAs(ComponentInvocationContextManager.java:333)
at weblogic.work.LivePartitionUtility.doRunWorkUnderContext(LivePartitionUtility.java:54)
at weblogic.work.PartitionUtility.runWorkUnderContext(PartitionUtility.java:41)
at weblogic.work.SelfTuningWorkManagerImpl.runWorkUnderContext(SelfTuningWorkManagerImpl.java:640)
at weblogic.work.ExecuteThread.execute(ExecuteThread.java:406)
at weblogic.work.ExecuteThread.run(ExecuteThread.java:346)
Caused By: [1] The class 'com.pega.pegarules.internal.etier.interfaces.PRRAConnectionFactory', which is defined as [<connectionfactory-interface>] from [META-INF/ra.xml], was not found in the resource adapter archive/application.
at weblogic.connector.external.impl.RAComplianceCheckerImpl.validate(RAComplianceCheckerImpl.java:253)
at weblogic.connector.external.impl.RAComplianceCheckerImpl.validate(RAComplianceCheckerImpl.java:242)
at weblogic.connector.common.RAInstanceManager.initialize(RAInstanceManager.java:1163)
at weblogic.connector.common.RAInstanceManager.<init>(RAInstanceManager.java:377)
at weblogic.connector.deploy.ConnectorModule.prepare(ConnectorModule.java:197)
at weblogic.application.internal.ExtensibleModuleWrapper$PrepareStateChange.next(ExtensibleModuleWrapper.java:295)
at weblogic.application.internal.ExtensibleModuleWrapper$PrepareStateChange.next(ExtensibleModuleWrapper.java:285)
at weblogic.application.internal.ExtensibleModuleWrapper.prepare(ExtensibleModuleWrapper.java:109)
