Labb
PH
Last activity: 22 Mar 2022 15:24 EDT
"Failed to generate excel. reason is Sheet1. Processign failed for sheet: Sheet1" pxGenerateExcelFile error
I cannot generate the results that I need when I'm using "pxGenerateExcelFile". I always encounter the "Failed to generate excel. reason is Sheet1. Processign failed for sheet: Sheet1" error. I have attached the screenshots of the parameters that I've used. I'm also using a action set for a button to call the pxGenerateExcelFile.
