Ernst & Young LLP
Last activity: 20 Feb 2018 12:00 EST
Failed to compile rule error for section rule
In our application We have one section name "MasterListMain" which has been circumstance using one property and has 44 circumstance version rules. It was working earlier. But suddenly this section not appearing and from log we got below error. Please help us to resolve the issue
2018-02-20 09:18:31,629 [ Proprietary information hidden:8443-75] [ABTHREAD10] [ ] [ NDP:01.02.01] ( pega.jsr199.Jsr199Bridge) ERROR fihe3nok1354.emea.nsn-net.net| Proprietary information hidden Rohit - Failed to compile rule: /com/pegarules/generated/html_section/ra_stream_masterlistmain_82cd08bb49edfc0e0018eb93f3f35986.java
2018-02-20 09:18:33,284 [ Proprietary information hidden:8443-75] [ABTHREAD10] [ ] [ NDP:01.02.01] (pcentric.RACacheAppCentricImpl) ERROR fihe3nok1354.emea.nsn-net.net| Proprietary information hidden Rohit - Failed to generate com.pegarules.generated.html_section.ra_stream_masterlistmain_82cd08bb49edfc0e0018eb93f3f35986
2018-02-20 09:18:33,295 [ Proprietary information hidden:8443-75] [ABTHREAD10] [ ] [ NDP:01.02.01] (pcentric.RACacheAppCentricImpl) ERROR fihe3nok1354.emea.nsn-net.net| Proprietary information hidden Rohit - Failed to generate com.pegarules.generated.html_section.ra_stream_masterlistmain_82cd08bb49edfc0e0018eb93f3f35986
2018-02-20 09:18:33,319 [ Proprietary information hidden:8443-75] [ABTHREAD10] [ ] [ NDP:01.02.01] (NDP_Work_GlobalActivity.Stream) ERROR fihe3nok1354.emea.nsn-net.net| Proprietary information hidden Rohit - Section 'MasterListMain' execution error on page 'pyWorkPage' of class 'NSN-NDP-Work-GlobalActivity'.
2018-02-20 09:18:33,324 [ Proprietary information hidden:8443-75] [ABTHREAD10] [ ] [ NDP:01.02.01] (ternal.mgmt.StreamBuilderTools) ERROR fihe3nok1354.emea.nsn-net.net| Proprietary information hidden Rohit - Problem appending stream null
Thanks in Advance,
Debabrata Paladhi
Hi Debabrata,
Can you please share the following information:
1.Is the section rule available or you are not able to find it?
2.If the section rule is available?Can you revalidate the section rule and check once?
Also,please share the complete stack trace
