Errors during Migration from UDF Enabled to UDF Disabled Environment
We are trying to migrate just the DATA schema from a system which had UDF enabled during installation, to a system which has UDF disabled (bypass.udf.generation set to true during base PegaRules install). We are seeing some JAVA_CLASS related errors during Datapump Import on Oracle. Can you please let us know if they are safe to ignore?
Example Error:
ORA-06550: line 1, column 33:
PL/SQL: Statement ignored
Failing sql is:
DECLARE STATUS NUMBER; BEGIN STATUS := DBMS_JAVA.START_IMPORT('com/pega/pegarules/data/internal/clipboard/directstream/InflaterV7', 0,29,0,4,3712,1); IF STATUS !=0 THEN IF STATUS > 0 THEN STATUS := -STATUS; END IF; execute immediate 'declare an exception; pragma exce
ORA-39083: Object type JAVA_CLASS failed to create with error:
You should be fine with the most of the prpc core features. UDF is mostly used for certain reports (unfortunately we do not have the list for you) when certain columns are not explicitly exposed.
