IBM
CN
Last activity: 14 Aug 2017 1:09 EDT
How to migrate automation tool from test environment to production environment
There is a same web application deployed in both test environment and production environment,and now I have to develop automation tool based on the web application in test environment firstly because of the limitation of production environment.
The issue i met is that it didn't work after migrating automation tool developed in test environment to production environment via changing the start page property of web.os ,like the URL of production is http://XXXX.com while test's is http://test.XXXX.com,I saw most elements are mismatched.It means i should interrogate the elements again,Is there any solution can fixed this issue?after all the web application is same.
Any help will be appreciated.
