DXC Technology
BE
Last activity: 7 Mar 2018 10:38 EST
Error while loading rules jar
Dears,
I am getting the below error while loading the rules jar. But the development team says that they have not done any changes to the mentioned table. Why is this showing up. Though it doesnt affect the jar import and doesnt throw errors during import.
[2/23/18 14:52:10:969 CET] 00000019 SystemOut O 2018-02-23 14:52:10,965 [.PRPCWorkManager : 3] [ STANDARD] [ ASL:01.46] ( internal.access.DatabaseImpl) ERROR id222222 - Error occured while trying to add Index columns for an property
com.pega.pegarules.pub.database.DatabaseException: Database-General Problem executing SQL to update database schema 1031 42000 ORA-01031: insufficient privileges
SQL: alter table ASL_RULES_SCHEMA.pr_index_circumstance_def add (pyTempText VARCHAR2(32) )
Caused by SQL Problems.
Problem #1, SQLState 42000, Error code 1031: java.sql.SQLSyntaxErrorException: ORA-01031: insufficient privileges
Dears,
at com.pega.pegarules.data.internal.access.ExceptionInformation.createExceptionDueToDBFailure(ExceptionInformation.java:262)
at com.pega.pegarules.data.internal.access.DatabaseImpl.executeDBSchemaDDL(DatabaseImpl.java:7259)
at com.pega.pegarules.data.internal.access.DatabaseImpl.executeDBSchemaUpdates(DatabaseImpl.java:7169)
at com.pega.pegarules.data.internal.access.DatabaseImpl.executeDBAddIndexColumns(DatabaseImpl.java:7094)
at com.pega.pegarules.session.internal.mgmt.Executable.executeDBAddIndexColumns(Executable.java:8256)
at com.pegarules.generated.activity.ra_action_savecircumstanceindex_5cc8fc82adff7c948485cb141ae9d1c8.step4_circum0(ra_action_savecircumstanceindex_5cc8fc82adff7c948485cb141ae9d1c8.java:666)
at com.pegarules.generated.activity.ra_action_savecircumstanceindex_5cc8fc82adff7c948485cb141ae9d1c8.perform(ra_action_savecircumstanceindex_5cc8fc82adff7c948485cb141ae9d1c8.java:130)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3500)
at com.pega.pegarules.exec.internal.declare.infengine.ChainingEngineUtilImpl.runActivity(ChainingEngineUtilImpl.java:225)
at com.pega.pegarules.exec.internal.declare.infengine.TriggerImpl.evaluateNetworks(TriggerImpl.java:307)
at com.pega.pegarules.data.internal.access.DatabaseImpl.performTriggers(DatabaseImpl.java:12809)
at com.pega.pegarules.data.internal.access.Saver.performTriggers(Saver.java:676)
at com.pega.pegarules.data.internal.access.Saver.saveDeferred(Saver.java:380)
at com.pega.pegarules.data.internal.access.DatabaseImpl.saveDeferred(DatabaseImpl.java:4951)
at com.pega.pegarules.data.internal.access.DatabaseImpl.saveDeferred(DatabaseImpl.java:14521)
at com.pega.pegarules.deploy.internal.loaders.SaverLoader.importContents(SaverLoader.java:457)
at com.pega.pegarules.deploy.internal.util.ImportImpl.performImport(ImportImpl.java:889)
at com.pega.pegarules.deploy.internal.util.ImportImpl.performImport(ImportImpl.java:762)
at com.pega.pegarules.deploy.internal.util.ImportImpl.importArchive(ImportImpl.java:670)
at com.pega.pegarules.deploy.internal.util.ImportImpl.importPegaArchive(ImportImpl.java:739)
at com.pega.pegarules.deploy.internal.archive.PegaArchiveAbstract.doImport(PegaArchiveAbstract.java:362)
at com.pegarules.generated.pxImportArchive_071017_w7IoE2VtDRzvUs1h_YGZlQ.pxImportArchive07_10_17(pxImportArchive_071017_w7IoE2VtDRzvUs1h_YGZlQ.java:142)
at com.pegarules.generated.pxImportArchive_071017_w7IoE2VtDRzvUs1h_YGZlQ.invoke(pxImportArchive_071017_w7IoE2VtDRzvUs1h_YGZlQ.java:84)
at com.pega.pegarules.generation.internal.library.LibraryRuntime.resolveAndinvokeFunctionViaReflection(LibraryRuntime.java:133)
at com.pega.pegarules.generation.internal.library.LibraryRuntime.invokeLibraryRuntime(LibraryRuntime.java:110)
at com.pega.pegarules.session.internal.mgmt.Executable.invokeLibraryRuntime(Executable.java:8954)
at com.pega.pegarules.priv.generator.LibrarySupport.resolveAndInvokeFunctionViaReflection(LibrarySupport.java:181)
at com.pegarules.generated.pega_importexport_pximportexport.pxImportArchive(pega_importexport_pximportexport.java:281)
at com.pegarules.generated.activity.ra_action_pegarulesmove_zip_to_db_8f7de3715a31006e8f8dda67c50322d5.step8_circum0(ra_action_pegarulesmove_zip_to_db_8f7de3715a31006e8f8dda67c50322d5.java:879)
at com.pegarules.generated.activity.ra_action_pegarulesmove_zip_to_db_8f7de3715a31006e8f8dda67c50322d5.perform(ra_action_pegarulesmove_zip_to_db_8f7de3715a31006e8f8dda67c50322d5.java:207)
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:646)
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivities(ThreadRunner.java:572)
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivities(PRThreadImpl.java:453)
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.executeBatchTask(QueueProcessor.java:257)
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.execute(QueueProcessor.java:320)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:945)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1259)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1008)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:901)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:670)
at com.pega.pegarules.session.internal.async.Agent.runBatchTask(Agent.java:815)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.AsyncServant.processAsyncTask(AsyncServant.java:230)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.AsyncServant.invoke(AsyncServant.java:167)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:315)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:263)
at com.pega.pegarules.session.internal.engineinterface.etier.ejb.EngineBean.invokeEngine(EngineBean.java:225)
at sun.reflect.GeneratedMethodAccessor136.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37)
at java.lang.reflect.Method.invoke(Method.java:611)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:367)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:408)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingException(AppServerBridgeToPega.java:245)
at com.pega.pegarules.internal.etier.ejb.EngineBeanBoot.invokeEngine(EngineBeanBoot.java:168)
at com.pega.pegarules.internal.etier.interfaces.EJSLocalStatelessEngineBMT_f2439d86.invokeEngine(Unknown Source)
at com.pega.pegarules.session.internal.engineinterface.etier.mdb.PRAsync.processRequest(PRAsync.java:155)
at com.pega.pegarules.session.internal.engineinterface.etier.asynchbeans.AsyncTask.run(AsyncTask.java:64)
at com.pega.pegarules.session.internal.engineinterface.etier.asynchbeans.RunnableWrapper.run(RunnableWrapper.java:71)
at com.ibm.ws.asynchbeans.J2EEContext$RunProxy.run(J2EEContext.java:271)
at java.security.AccessController.doPrivileged(AccessController.java:399)
at com.ibm.ws.asynchbeans.J2EEContext.run(J2EEContext.java:797)
at com.ibm.ws.asynchbeans.WorkWithExecutionContextImpl.go(WorkWithExecutionContextImpl.java:222)
at com.ibm.ws.asynchbeans.ABWorkItemImpl.run(ABWorkItemImpl.java:206)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1731)
Caused by:
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:439)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:395)
at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:802)
at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:436)
at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:186)
at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:521)
at oracle.jdbc.driver.T4CStatement.doOall8(T4CStatement.java:194)
at oracle.jdbc.driver.T4CStatement.executeForRows(T4CStatement.java:1000)
at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1307)
at oracle.jdbc.driver.OracleStatement.executeInternal(OracleStatement.java:1882)
at oracle.jdbc.driver.OracleStatement.execute(OracleStatement.java:1847)
at oracle.jdbc.driver.T4CStatement.execute(T4CStatement.java)
at oracle.jdbc.driver.OracleStatementWrapper.execute(OracleStatementWrapper.java:301)
at com.ibm.ws.rsadapter.jdbc.WSJdbcStatement.pmiExecute(WSJdbcStatement.java:1579)
at com.ibm.ws.rsadapter.jdbc.WSJdbcStatement.execute(WSJdbcStatement.java:722)
at com.pega.pegarules.data.internal.access.GenericExecutor.execute(GenericExecutor.java:31)
at com.pega.pegarules.data.internal.access.DatabaseImpl.executeDBSchemaDDL(DatabaseImpl.java:7247)
... 63 more
