Centene
Last activity: 11 Mar 2021 4:30 EST
Error: Stream service is not running in the cluster.
In our cloud development environment, we notice the error "Error: Stream service is not running in the cluster. in Admin Studio under "System & Nodes".
What wrong configuration is causing this error?
What version?
For the Queue Processor to work in the cluster, it requires 3 node types (BackgroundProcessing, Search, and Stream), you do not have that here.
Maybe you should try Universal instead (-DNodeType=Universal) ? This specifies that the node is assigned all node types. Or else add more nodes until you meet the 3 required types
Is this pegacloud or your own on-prem cloud? In any case, you need to start a stream node (-DNodeType=Stream), which is required for pega 8.x.
Centene
We have 2 webnodes and we are not using any streaming services. Still do we need a streaming node?
Venkateswararao Kurra
Centene
Kevin,
Even after adding a stream node, application is still showing the same error.
Louis Dreyfus Company
FR
1. It is not recommended to disable Stream nodes.
Disabling of Stream nodes can be done by selecting a different node type but it will break existing queue processors (It mean losing the ability to use FTS etc.)
the links below should give You further details to understand the topic:
https://community.pega.com/sites/default/files/help_v81/procomhelpmain.htm#rule-/rule-async-/rule-async-queueprocessor/main.htm
https://community.pega.com/knowledgebase/queue-processor-faq
https://community.pega.com/knowledgebase/articles/kafka-streaming-service
https://community.pega.com/knowledgebase/articles/stream-service-overview
https://community.pega.com/sites/default/files/help_v74/procomhelpmain.htm#dsm/tasks/dsm-node-configuring-stream-service-tsk.htm
https://community.pega.com/sites/default/files/help_v74/procomhelpmain.htm#dsm/references/dsm-stream-service-node-overview-ref.htm
2. Stream node is required to run queue processor (QP) since Pega 8.
OOTB we ship 3 QPR (pyProcessNotification, pzStandardProcessor and pyFTSIncrementalIndexer).
These are fundamental for Platform's correct functioning. without a stream node, they can't be executed
So, in single-node environment, You can omit the nodetype (or run with universal nodeType). In a multi node, You need at least one Stream node.
You can verify if it's working properly by going to Configure ==> Decisioning ==> Infrastructure
Then click on stream and be sure one node is active there.
Once it's ok, go to Data Flow ( still under infrastructure ) and verify that you have one node for BackgroundProcessing and Search
After that it should be good.
Loïc
What version?
FR
Ming Ee Lai
Centene
Thank you. It worked after setting up 3 kinds of nodes.
Morgan Stanley
We had similar issue though every node is setup as universal
Energy Safe Australia
We are also facing the same issue, we got one node set as Stream,BackgroundProcessing,WebUser,Search and another as just WebUser. The nodes are running NORMAL (Stream,Search,BackgroundProcessing) initially and after few hours only WebUser is working and we are getting thread dumps and on restart below errors
0-05-10 13:49:32,134 [1,10,19,2,3,4,7,8,9]] [ STANDARD] [ ] [ ] (w.listener.RetryLoggerListener) ERROR - [pyFTSIncrementalIndexer] Preparing retry 1. Next attempt in 1s on data flow [pyFTSIncrementalIndexer] on stage [InputStage] with affected partitions: [0, 1, 10, 19, 2, 3, 4, 7, 8, 9]
java.util.concurrent.CompletionException: com.pega.fnx.stream.spi.StreamServiceException: Stream SPI error
at java.util.concurrent.CompletableFuture.encodeThrowable(Unknown Source) ~[?:1.8.0_201]
at java.util.concurrent.CompletableFuture.completeThrowable(Unknown Source) ~[?:1.8.0_201]
at java.util.concurrent.CompletableFuture$AsyncSupply.run(Unknown Source) ~[?:1.8.0_201]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:1.8.0_201]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:1.8.0_201]
at java.lang.Thread.run(Unknown Source) [?:1.8.0_201]
Bien Etre assistance
FR
Hi @DharanitharanR5430, I have the same issue, have you solved it?
Sudesh Jethoe Joseph Srikanth Katakam Callum Sharkey
