Banco Colpatria Multibanca Colpatria
CO
Error: reference to OpenSpan.Design.IComponentIndex Service
I am using Pega and Visual Studio 2015 to search and select text in a pdf. I am using PDF Connector and PDFViewer in Visual Studio 2015 and when I run the automation this error occurs.
I have looked for help in different places and I have not been able to solve it.
I appreciate the help you can give me.
attached error image
best regard!
Elider Sánchez
CO
Right click on the pdf adapter in the object explorer and select "validate connections", then clean the project and try again.
CO
Good Morning
I made the steps as indicated and still keeps presenting the same error. Is there any way to add or install that reference manually in the computer?
What other option can be done? I thank you for your help.
Thank you.
Attached image of the error.
best regard!
CO
good day
bye
CO
Please help me!
Hello EliderS5,
When you look at the properties for the pdfViewer you will see that there is a 'Connector' property under the 'PDF' Category. This does not set a value by default but you can choose to set the pdfConnector found in you global container (image attached for reference)
If you have not done this, set the value to your pdfConnector and try again. Please let me know what your results are.
CO
Hello Lopec
thanks for your answer.
But that step had already taken place.
attached image.
Thank you
CO
Please help me!
Can to try adding a reference to OpenSpan.Design.dll to your project. You can browse for this DLL in the C:\Program Files(x86)\OpenSpan\OpenSpan Studio for Microsoft Visual Studio 2015 folder
CO
Please help me!
Thanks!
Please open a Support Request, as this issue will need to be investigated in more detail. If you do not have access to the Support Portal, contact your Support Portal Administrator so that a Support Request can be opened on your behalf.
CO
The following SR-C5786 was created for this case.
Thank you
Regards
Thank you @EliderSanchezR! I've updated your original post with that SR information and linked this post to your SR with our Support Engineers.
CO
Hi community
Good news, I updated the version of Pega and it works correctly. Christopher Heffernan helped me.
Thanks for all the support.
Regards
Hi community
Regards
