Error running upgrade script: FirstUseAssemblerException FUACache-FailAssembly [this:is:not:a:classname] produced no java source
Getting the following error when running upgrade.sh:
[java] 2015-07-01 14:22:59,871 [mchase.net] INFO - Processing Starting Rule : RULE-OBJ-ACTIVITY RULE-MESSAGE ONBEFOREDISPLAY #20140930T092359.996 GMT
[java] 2015-07-01 14:22:59,901 [mchase.net] INFO - Processing Starting Rule : RULE-OBJ-ACTIVITY EMBED-SUMMARYPARAMS GETCONTENTDAILYTREND #20130919T000442.491 GMT
[java] 2015-07-01 14:22:59,925 [mchase.net] INFO - Processing Starting Rule : RULE-OBJ-ACTIVITY EMBED-COLLECTION-STEP-PRIMARY PZPRESAVE #20140811T193205.582 GMT
[java] Jul 01, 2015 2:23:04 PM com.pega.pegarules.internal.bootstrap.PRBootstrap
[java] SEVERE: Problem during method invocation (main)
[java] com.pega.pegarules.pub.PRRuntimeError: PRRuntimeError
[java] at com.pega.pegarules.session.internal.mgmt.Executable.doAction(Executable.java:3316)
[java] at com.pega.pegarules.data.internal.access.TemplateRuleChooserImpl.<init>(TemplateRuleChooserImpl.java:79)
[java] at com.pega.pegarules.data.internal.access.RuleResolver.getRuleChooser(RuleResolver.java:829)
[java] at com.pega.pegarules.data.internal.access.RuleResolver.resolveRuleToCandidate(RuleResolver.java:786)
[java] at com.pega.pegarules.data.internal.access.RuleResolver.resolveRuleToCandidate(RuleResolver.java:737)
[java] at com.pega.pegarules.data.internal.access.RuleResolver.resolveAndGetRuleCandidate(RuleResolver.java:1096)
[java] at com.pega.pegarules.data.internal.access.DatabaseImpl.getInsHandle(DatabaseImpl.java:4256)
[java] at com.pega.pegarules.data.internal.access.DatabaseImpl.getInsHandle(DatabaseImpl.java:3724)
[java] at com.pega.pegarules.generation.internal.assembly.staticassembly.smartconfig.cache.ReferenceCache.loadReferencesFor(ReferenceCache.java:227)
[java] at com.pega.pegarules.generation.internal.assembly.staticassembly.smartconfig.cache.ReferenceCache.getReferencesFor(ReferenceCache.java:104)
[java] at com.pega.pegarules.generation.internal.assembly.staticassembly.smartconfig.ProcessReferences.processRule(ProcessReferences.java:101)
[java] at com.pega.pegarules.generation.internal.assembly.staticassembly.smartconfig.ProcessReferences.processRules(ProcessReferences.java:76)
[java] at com.pega.pegarules.generation.internal.assembly.staticassembly.smartconfig.BaseAppAndRefRulesProcessor.generateConfig(BaseAppAndRefRulesProcessor.java:80)
[java] at com.pega.pegarules.generation.internal.assembly.staticassembly.smartconfig.SmartConfigGenerator.generateConfig(SmartConfigGenerator.java:109)
[java] at com.pega.pegarules.generation.internal.assembly.staticassembly.smartconfig.SmartConfigGenerator.main(SmartConfigGenerator.java:186)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
[java] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
[java] at java.lang.reflect.Method.invoke(Method.java:606)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:367)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:408)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:272)
[java] at com.pega.pegarules.pub.PegaRULES.main(PegaRULES.java:85)
[java] Caused by: com.pega.pegarules.pub.generator.FirstUseAssemblerException: FUACache-FailAssembly [this:is:not:a:classname] produced no java source
[java] From: (BF102EE792855DE584727F36FC53B37F8)
[java] at com.pega.pegarules.generation.internal.cache.AssemblerFunctions.assembleRule(AssemblerFunctions.java:179)
[java] at com.pega.pegarules.generation.internal.cache.AssemblyCacheBase.buildAndOrLoadJavaClass(AssemblyCacheBase.java:1659)
[java] at com.pega.pegarules.generation.internal.cache.AssemblyCacheBase.getGeneratedJava(AssemblyCacheBase.java:3070)
[java] at com.pega.pegarules.generation.internal.cache.appcentric.RACacheAppCentricImpl.addEntryToMemoryCache(RACacheAppCentricImpl.java:1142)
[java] at com.pega.pegarules.generation.internal.cache.appcentric.RACacheAppCentricImpl.find(RACacheAppCentricImpl.java:989)
[java] at com.pega.pegarules.generation.internal.cache.AssemblyCacheWrapper.find(AssemblyCacheWrapper.java:799)
[java] at com.pega.pegarules.generation.internal.assembly.FUAManagerImpl.getInternal(FUAManagerImpl.java:1408)
[java] at com.pega.pegarules.generation.internal.assembly.FUAManagerImpl.get(FUAManagerImpl.java:1296)
[java] at com.pega.pegarules.generation.internal.PRGenProviderImpl.get(PRGenProviderImpl.java:476)
[java] at com.pega.pegarules.session.internal.mgmt.Executable.doAction(Executable.java:3293)
[java] ... 23 more
[java]
[java] Jul 01, 2015 2:23:04 PM com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega
[java] ... 23 more
[java]
[java] Exception in thread "psin5p355.svr.us.jpmchase.net" java.lang.RuntimeException: Problem during method invocation (main)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:278)
[java] Caused by: com.pega.pegarules.pub.PRRuntimeError: PRRuntimeError
[java] ... 1 more
[java] ... 23 more
BUILD FAILED
/dev/shm/Pega7DBpackages/scripts/setupDatabase.xml:317: The following error occurred while executing this line:
/dev/shm/Pega7DBpackages/scripts/setupDatabase.xml:2472: The following error occurred while executing this line:
/dev/shm/Pega7DBpackages/scripts/utils/staticAssemblerResources/scripts/staticAssembler.xml:523: The following error occurred while executing this line:
/dev/shm/Pega7DBpackages/scripts/utils/staticAssemblerResources/scripts/staticAssembler.xml:491: Java returned: 1
***Updated by moderator: Lochan to close post***
