Error in logs - CPU Timer recorded zero or negative Wall Time mTimers
I am seeing below error in logs of PE v7.1.6. How do i rectify this error?
PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:07.10] ( external.timers.CpuTimer) ERROR - CpuTimer recorded zero or negative Wall Time mTimers:[1000000000, 6, 1000000000, 2, 1000000000, 2, -28323143944000, 0, 225420000000, 858375045, 13500000000] mTimerLevel:TOTALSONLY mOverrideCpuTimerLevel:true oTimeProvider:class com.pega.pegarules.exec.external.timers.JavaTimeProvider oWallTimeOnlyProvider:class com.pega.pegarules.exec.external.timers.WallTimeProvider
java.lang.Throwable
at com.pega.pegarules.exec.external.timers.CpuTimer.update(CpuTimer.java:732)
at com.pega.pegarules.exec.external.timers.CpuTimerFactory.acquire(CpuTimerFactory.java:88)
at com.pega.pegarules.monitor.internal.pal.PALDurationImpl._stopTiming(PALDurationImpl.java:484)
at com.pega.pegarules.monitor.internal.pal.PALDurationImpl.stopTiming(PALDurationImpl.java:366)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:887)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1192)
java.lang.Throwable
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:930)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:829)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:617)
at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:991)
at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:532)
at java.lang.Thread.run(Thread.java:722)
Thanks!
Sabarivasan
