HCL Technologies
Last activity: 7 Aug 2023 10:34 EDT
Error Getting Current Database time
Hi ,
when i am executing the pega 8.5 upgrade or install script i am getting the below error
Hi ,
2020-12-03 21:14:12,104 [ervice-registry-task] [ STANDARD] [ ] [ ] (rsistence.DatabaseTimeProvider) ERROR - Could not retrieve the database time
com.pega.pegarules.pub.PRRuntimeException: PRRuntimeException
at com.pega.pegarules.data.internal.sqlapi.exec.NativeSQLListExecutor.execute(NativeSQLListExecutor.java:85) ~[prprivate-data.jar:8.5.1-208]
at com.pega.pegarules.data.internal.sqlapi.exec.NativeSQLListExecutor.execute(NativeSQLListExecutor.java:52) ~[prprivate-data.jar:8.5.1-208]
at com.pega.pegarules.data.internal.PRDataProviderImpl.executeNativeSQL(PRDataProviderImpl.java:1663) ~[prprivate-data.jar:8.5.1-208]
at com.pega.pegarules.data.internal.PRDataProviderForModulesImpl.executeNativeSQL(PRDataProviderForModulesImpl.java:138) ~[prprivate-data.jar:8.5.1-208]
at com.pega.platform.serviceregistry.internal.database.persistence.DatabaseTimeProvider.get(DatabaseTimeProvider.java:61) ~[service-registry.jar:8.5.1-208]
at com.pega.platform.serviceregistry.internal.database.tasks.FailedServiceCleaner.execute(FailedServiceCleaner.java:62) ~[service-registry.jar:8.5.1-208]
at com.pega.platform.serviceregistry.internal.database.tasks.TaskExecutor.execute(TaskExecutor.java:74) ~[service-registry.jar:8.5.1-208]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:1.8.0_222]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) ~[?:1.8.0_222]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) ~[?:1.8.0_222]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) ~[?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) ~[?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) ~[?:1.8.0_222]
at com.pega.platform.serviceregistry.internal.PrThreadFactory$PrpcThread.run(PrThreadFactory.java:71) ~[service-registry.jar:8.5.1-208]
Caused by: com.pega.pegarules.data.internal.rd.queryexec.ExecuteQueryException: An error occured on executing the query for the report definition - There was a problem getting a list: code: 933 SQLState: 42000 Message: ORA-00933: SQL command not properly ended
DatabaseException caused by prior exception: java.sql.SQLSyntaxErrorException: ORA-00933: SQL command not properly ended
| SQL Code: 933 | SQL State: 42000
at com.pega.pegarules.data.internal.sqlapi.queryexec.NativeSQLQueryExecutor.executeQuery(NativeSQLQueryExecutor.java:84) ~[prprivate-data.jar:8.5.1-208]
at com.pega.pegarules.data.internal.sqlapi.queryexec.NativeSQLQueryExecutor.executeQuery(NativeSQLQueryExecutor.java:51) ~[prprivate-data.jar:8.5.1-208]
at com.pega.pegarules.data.internal.sqlapi.exec.NativeSQLListExecutor.executeQuery(NativeSQLListExecutor.java:135) ~[prprivate-data.jar:8.5.1-208]
at com.pega.pegarules.data.internal.sqlapi.exec.NativeSQLListExecutor.executeSql(NativeSQLListExecutor.java:117) ~[prprivate-data.jar:8.5.1-208]
at com.pega.pegarules.data.internal.sqlapi.exec.NativeSQLListExecutor.execute(NativeSQLListExecutor.java:82) ~[prprivate-data.jar:8.5.1-208]
... 13 more
Caused by: com.pega.pegarules.pub.database.DatabaseException: There was a problem getting a list: code: 933 SQLState: 42000 Message: ORA-00933: SQL command not properly ended
at com.pega.pegarules.data.internal.access.ExceptionInformation.createAppropriateExceptionDueToDBFailure(ExceptionInformation.java:385) ~[prprivate-data.jar:8.5.1-208]
at com.pega.pegarules.data.internal.access.ExceptionInformation.createExceptionDueToDBFailure(ExceptionInformation.java:364) ~[prprivate-data.jar:8.5.1-208]
at com.pega.pegarules.data.internal.access.Lister.convertSqlExceptionToDatabaseException(Lister.java:618) ~[prprivate-data.jar:8.5.1-208]
at com.pega.pegarules.data.internal.access.Lister.listWithResultPackager(Lister.java:434) ~[prprivate-data.jar:8.5.1-208]
at com.pega.pegarules.data.internal.access.Lister.list(Lister.java:190) ~[prprivate-data.jar:8.5.1-208]
at com.pega.pegarules.data.internal.access.DatabaseImpl.list(DatabaseImpl.java:3027) ~[prprivate-data.jar:8.5.1-208]
at com.pega.pegarules.data.internal.access.DatabaseImpl.list(DatabaseImpl.java:3018) ~[prprivate-data.jar:8.5.1-208]
at com.pega.pegarules.data.internal.sqlapi.queryexec.NativeSQLQueryExecutor.executeQuery(NativeSQLQueryExecutor.java:98) ~[prprivate-data.jar:8.5.1-208]
at com.pega.pegarules.data.internal.sqlapi.queryexec.NativeSQLQueryExecutor.executeQuery(NativeSQLQueryExecutor.java:75) ~[prprivate-data.jar:8.5.1-208]
... 13 more
Caused by: java.sql.SQLSyntaxErrorException: ORA-00933: SQL command not properly ended
at oracle.jdbc.driver.T4CTTIoer11.processError(T4CTTIoer11.java:494) ~[ojdbc8- Proprietary information hidden.jar: Proprietary information hidden.0]
at oracle.jdbc.driver.T4CTTIoer11.processError(T4CTTIoer11.java:446) ~[ojdbc8- Proprietary information hidden.jar: Proprietary information hidden.0]
at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:1054) ~[ojdbc8- Proprietary information hidden.jar: Proprietary information hidden.0]
at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:623) ~[ojdbc8- Proprietary information hidden.jar: Proprietary information hidden.0]
at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:252) ~[ojdbc8- Proprietary information hidden.jar: Proprietary information hidden.0]
at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:612) ~[ojdbc8- Proprietary information hidden.jar: Proprietary information hidden.0]
at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:226) ~[ojdbc8- Proprietary information hidden.jar: Proprietary information hidden.0]
at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:59) ~[ojdbc8- Proprietary information hidden.jar: Proprietary information hidden.0]
at oracle.jdbc.driver.T4CPreparedStatement.executeForDescribe(T4CPreparedStatement.java:747) ~[ojdbc8- Proprietary information hidden.jar: Proprietary information hidden.0]
at oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:904) ~[ojdbc8- Proprietary information hidden.jar: Proprietary information hidden.0]
at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1082) ~[ojdbc8- Proprietary information hidden.jar: Proprietary information hidden.0]
at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3780) ~[ojdbc8- Proprietary information hidden.jar: Proprietary information hidden.0]
at oracle.jdbc.driver.T4CPreparedStatement.executeInternal(T4CPreparedStatement.java:1343) ~[ojdbc8- Proprietary information hidden.jar: Proprietary information hidden.0]
at oracle.jdbc.driver.OraclePreparedStatement.execute(OraclePreparedStatement.java:3887) ~[ojdbc8- Proprietary information hidden.jar: Proprietary information hidden.0]
at oracle.jdbc.driver.OraclePreparedStatementWrapper.execute(OraclePreparedStatementWrapper.java:1079) ~[ojdbc8- Proprietary information hidden.jar: Proprietary information hidden.0]
at com.zaxxer.hikari.pool.ProxyPreparedStatement.execute(ProxyPreparedStatement.java:44) ~[HikariCP-java7-2.4.12.jar:?]
at com.zaxxer.hikari.pool.HikariProxyPreparedStatement.execute(HikariProxyPreparedStatement.java) ~[HikariCP-java7-2.4.12.jar:?]
at com.pega.pegarules.data.internal.store.DatabasePreparedStatementImpl.execute(DatabasePreparedStatementImpl.java:531) ~[prprivate-data.jar:8.5.1-208]
at com.pega.pegarules.data.internal.access.Lister.listWithResultPackager(Lister.java:415) ~[prprivate-data.jar:8.5.1-208]
... 13 more
Caused by: oracle.jdbc.OracleDatabaseException: ORA-00933: SQL command not properly ended
at oracle.jdbc.driver.T4CTTIoer11.processError(T4CTTIoer11.java:498) ~[ojdbc8- Proprietary information hidden.jar: Proprietary information hidden.0]
... 13 more
Any idea what the root cause or the issue could be?
