Bank of New Zealand
Last activity: 27 Jun 2016 21:42 EDT
Date Time field defaults to current time after upgrade
Issue with the Date-Time Calendar after upgrading from PRPC 6.1 to Pega 7.1.7. In the earlier version, the time is defaulted to 12:00 AM but in Pega 7.1.7 it defaults to current time.
I verified the related Support Article SA-12489.
PegaSystems suggested the following change to make the time defaulted to "00:00"
1. Create a non-auto generated section with below code.
<script>
try {
var dateTimeControlsIDs = [""];
debugger;
for (var idx = 0; idx < dateTimeControlsIDs.length; idx++) {
var iconSpanObj = document.getElementById(dateTimeControlsIDs[idx]);
if (iconSpanObj) {
pega.util.Event.removeListener(iconSpanObj, 'click', setDefaultHoursAndMinutes);
pega.util.Event.addListener(iconSpanObj, 'click', setDefaultHoursAndMinutes);
} catch(e) { }
function setDefaultHoursAndMinutes(event) {
var _element = pega.util.Event.getTarget(event);
setTimeout(function() {
if (_element && _element.parentNode) {
var inputElem = pega.util.Dom.getFirstChild(_element.parentNode);
if (inputElem && inputElem.value != "") {
return;
var hoursDropObj = document.getElementById("hourDrop");
if(hoursDropObj) {
var listLength = hoursDropObj.options.length;
for (var i = 0; i < listLength; i++) {
if (hoursDropObj.options[i].value == 0) {
hoursDropObj.options[i].selected = true;
hoursDropObj.options[i].defaultSelected = true;
var minuteDropObj = document.getElementById("minuteDrop");
listLength = minuteDropObj.options.length;
if (minuteDropObj.options[i].value == 0) {
minuteDropObj.options[i].selected = true;
minuteDropObj.options[i].defaultSelected = true;
}, 100);
</script>
2. Include this section, into the master section.
but this approach is not working. still the date time is set to current date time. Is there anything else we need to do to set the time to "12:00 AM" or 00:00?
Message was edited by: Joe Stalin Thanks for your response, I will check and reply you soon. Joe Stalin
