Enabling Traditional UI in Constellation Breaks All Existing Constellation Case Types
Hello! When experimenting with the Traditional UI in Constellation feature set in Pega 24.1, I found that after enabling a landing page from a Traditional UI application, all of my existing Constellation based Case Types were suddenly unable to be edited. They all exist within the Constellation based application and not the Traditional UI application, however they are being treated like Case Types that came from the Traditional UI application.
In an attempt to troubleshoot I also found that when generating a new Case Type within that Constellation application after using Traditional UI in Constellation does not change the outcome, I am still unable to edit it with the error: "Editing traditional Case Types in a Constellation application is not supported and might produce unexpected behaviour or potentially corrupt the Case.
You can edit your Case Type in the traditional application, and the changes will be propagated to the Constellation application automatically."
Is there any known fix to this?
