Edit Validate Rules
Can we configure Edit validate Rules in both ways? 1) when the form is submitted 2) when the user exits a field
In the 'Methods of data validation' section , it is given that
Edit validate rules run when the user exits a field if the harness rule is configured to support client-side validation. Otherwise, edit validate rules are run when the user submits a form.
The standard harnesses provided with the Pega Platform are configured to support client-side validation.
In 'How to use edit validate rules' section
You can use an edit validate rule to ensure that the field contains the
symbol. If it does not, an error message appears when the form is submitted.
