Edit validate rule v.s. validate rule.
What are the best practices when choosing edit validate rule v.s. validate rule?
- Edit Validate Rule: used for pattern-masking on properties, hence referenced on property rule itself and is always called when property is updated.
- Validate Rule: used for validation of property values via conditions, hence this is referenced where needed, usually in a Flow Action rule.
https://pdn.pega.com/community/product-support/question/edit-validate-edit-input-validate-rule
Thank You.
Thank You.
Thanks.
Hi pchep,
Can you take a look at below link? It will provide you some help.
Susan
Thanks.
