Easiest way to fix duplicate rule instance issue in same ruleset version
Hi All - Can you guys please share your experience or way to resolve this issue.
Actually after importing multiple times same package in higher environment we are seeing duplicate instances of same rule in same ruleset version. For example we have a Rule R1 in Ruleset RS1 in version 01-01-01 then after importing the zip 3 times in higher environment I can see 2 instances of same rule R1 in RS1:01-01-01.
Earlier when I faced this issue in 6.x and lower I used to do Revalidate and Save or some time unlock the ruleset version and delete the rule from that version in higher environment and then reimport the package and it used to work. but this time I see more than 4 rules have this issue so wanted to check with experts here in the forum that what's the best way to deal with this situation? Currently I am using 7.1.5.
