Does Pega support open telemetry standard?
Does Pega already support open telemetry standard?
In case it doesn't support it, is it going to support it?
@AleMax225 Hi PDC has all the required telemetry metrics available processed.
if you have PDC already available as part of your licenses then , you should be able to get the required metrics.
Hi @AleMax225,
Yes, Pega does support the Open Telemetry standard.
@SudheerKumarGoudB3761 have you ever used it, and in case, how did you implemented it?
