AMEX
Last activity: 9 Dec 2015 11:37 EST
Do we have Automated Testing in 7.1.8 for REST Services.? PDN Search shows only SOAP Services.. Is there any other mechanism for REST Services Automation.?
As part of our testing, we are planning to test the rest
services. But in PDN I see that the automation testing is enabled for SOAP
services and not REST.
Is there a mechanism to perform automated test cases for REST services?
A lot of our clients use 3rd party tool like SOAPUI for unit and load tests, including SOAP and REST services. The SOAPUI projects are normally very easy to set up and tests can be easily automated. Are you looking for something specific here?
AMEX
Thank you for the information.
I am looking for something specific from Pega side as we have for Service SOAP.
Is there any plan of implementing Automation testing on PegaREST services for later version of Pega 7?
What SOAP service automated testing are you talking about? Is it by clicking Actions -> Run from the SOAP service rule form? If yes, you can do the same from Service REST rule form as well.
AMEX
Yes. I know about the service rule form test run.
My Question is regarding the automation. The same way we have for SOAP (recording and running test cases)
I have not seen the recording and execution feature inside Pega 7 w.r.t. SOAP test. Can you share the screen capture of the SOAP test (recording and running test cases) that you have mentioned?
-Adi
Updated: 7 Dec 2015 14:11 EST
AMEX
Updated: 8 Dec 2015 8:35 EST
I don't see similar feature for REST. It seems like a good enhancement.
Updated: 8 Dec 2015 9:00 EST
I only found reference from Service-SOAP to record button. Most likely this is not supported OOTB for REST-Service although I think it would be a good enhancement feature.
Hi Venkata,
A User Story has been opened for this. Product team will analyze and triage this for future releases.
-Adi
AMEX
Thank you All for your responses.
Thanks once again for all your help..
