AARETE
Last activity: 26 Sep 2018 10:12 EDT
Display issue with application skin
Hello Everyone,
I'm facing an issue with my designer studio when I try to open application skin.After logging into Designer Studio when I try to open skin I'm not able to see the application skin for some applications.Below is the screenshot of distorted UI.
Kishore.
Hi Kishore,
It looks a caching issue. Can you try to stop the server, cleanup the temp directory and restart the server?
Susan
AARETE
I'm still having the same issue.
Updated: 7 Aug 2018 15:08 EDT
It seems like some of the scripts is not getting loaded. Are you facing this issue across browsers? Also, are you getting some exception in the Console tab in Developers tools? And is the issue only happening for App Skin?
AARETE
Yes, I'm facing this issue across all the browsers.Yeah this issue happening when I open app skin
Swedbank AB
SE
Can you add pega-ui ruleset in implementation application and check once.
AARETE
I have added the pega-ui ruleset but I still see this issue.
Tata Consultancy Services
Can you check UI Kit?
AARETE
Yes I have checked
