Disabling a REST or SOAP service on Pega 7 cluster node ?
Colleagues,
Is there a particular way in Pega 7 to disable a REST or SOAP service on a given node ? May be a prconfig settings or similar ?
Context is as follow : while deploying the same application on several cluster nodes with a shared DB, we would like to disable some Http services on Pega nodes deployed in a Semi-Trusted network zone.
Djibril
Hi Djibril,
If we wanted to disable all the services on a given node, we can remove the entry for PRRestService but if it is only for some few services, then we might need handle as part of service activity.
