LTIMindtree
LTIMindtree
LTIMindtree
Posted: Aug 7, 2019
Last activity: Aug 21, 2019
Last activity: 21 Aug 2019 5:13 EDT
Deleting Case on click button
i want to delete draft cases existing cases for the user on click on delete button, the cases should be delete from work list of user
Generally, work object information stored in the respective work table. If that work object is assigned to a particular user then assign page information will be stored under Assign-WorkList table.
If you delete that record from the table then you cannot see the cases under user worklist.
But, Deleting the entries from Assign-WorkList table is not good practice. Later, you will see the side effects of it.
Instead of deleting, It's better to assign those cases to work basket.
