On-click button is not function
Hi, I want to continue the case that assigns to the work queue. So I click the "Go" button but seems it is not running properly. I am still on the same page, nothing happens. Anyone has an idea why it happens?
@Intandhp can you trace and check if you are able to identify any errors? You will have case link also which takes you to review harness. Is that working?
