Wagner Development Solutions
HU
Last activity: 30 Jul 2020 0:22 EDT
Data Flow rule is not created for Queue Processor
When I create a new dedicated Queue Processor in Pega v8.3 the associated Data Flow instance should be generated by the system but it isn't.
The result is that the specified Activity is not invoked and on the Admin Portal the status of the created Queue Processor is empty. Also if I click on the row menu (three dots) and select the View Data Flow I get an error that the ID is empty.
If I open the instances for Pega-DM-DDF-Work, there is no instance associated with my Queue Propessor.
The node is configured properly (has BackgroundProcessing and Stream types) and also system runtim configuration is fine.
