Data flow not capturing results
Hi all,
I am very new to Pega Decisioning.
While going through the CPDC course I found that the Interaction shape which was available till Pega 7.2 is no more available in Pega 7.3. In 7.3 it is replaced by Data flows. In the interaction rule there was an option 'Write Results To' under which we can select Clipboard and mention a page name on which the data will be copied. This option is not present in data flows. Due to this I am not able to get the strategy results on clipboard page. While tracing in 7.2 I can see that when strategy is called from the Interaction rule, the step page is the page mentioned in Interaction rule. While calling the strategy rule from data flows the step page is 'unanamed'.
Options I tried
1. I tried to use various combinations in 'Output Strategy Results' but was not able to get the propositions returned by my strategy. If I use Interaction rule in 7.2 it returns the offered proposition on an independent clipboard page Customer.OfferedPropositions.
2. Tried to use the destination configurations, but I was not clear how can I map it on a independent clipboard page? Do I have to call an activity to do the mapping? If yes what should be the source page?
Request community members to explain how the strategy results can be saved on clipboard page while using data flow?
You can download the first lesson solution zip from CPDC course and try this quickly in 7.2 and 7.3
Any help is greatly appreciated.
Aniket
Hi all,
Options I tried
Aniket
