Verizon Wireless
Last activity: 12 Oct 2018 15:01 EDT
DATA-ADMIN-SYSTEM-SETTINGS ! (java.lang.NullPointerException) on the monitored nodes during the AES upgrade from 717 to 72.
Hi Team,
The below mentioned exceptions has been observed in the logs of the monitored nodes while trying to implement AES upgrade from 717 to 72. (AES standalone).
Please suggest about the possible reason that can cause the issue mentioned below.
Hi Team,
2017-08-09 22:07:36,466 [2e6c9fbe41df.event-1] [ STANDARD] [ ] ( internal.access.DatabaseImpl) ERROR - Unhandled exception on Data-Admin-System-Settings DATA-ADMIN-SYSTEM-SETTINGS ! (java.lang.NullPointerException): null
at com.pega.pegarules.exec.internal.basic.SystemSettingsImpl.processDynamicAppenders(SystemSettingsImpl.java:571)
at com.pega.pegarules.exec.internal.basic.SystemSettingsImpl.notePulseChange(SystemSettingsImpl.java:556)
at com.pega.pegarules.data.internal.access.DatabaseImpl.removeFromNodeCache_(DatabaseImpl.java:9299)
at com.pega.pegarules.data.internal.access.DatabaseImpl.processChanges(DatabaseImpl.java:9581)
at com.pega.pegarules.data.internal.access.DatabaseImpl.processChangesFromPulse(DatabaseImpl.java:9345)
at com.pega.pegarules.cluster.internal.pulseprocessor.PRPulseCacheProcessor.execute(PRPulseCacheProcessor.java:68)
at com.pega.pegarules.cluster.internal.pulseprocessor.PRPulseDispatcher.processPulseMessages(PRPulseDispatcher.java:152)
at com.pega.pegarules.cluster.internal.PRClusterHazelcastImpl$PulseListener.onMessage(PRClusterHazelcastImpl.java:939)
at com.hazelcast.topic.impl.TopicService.dispatchEvent(TopicService.java:136)
at com.hazelcast.spi.impl.EventServiceImpl$EventPacketProcessor.process(EventServiceImpl.java:549)
at com.hazelcast.spi.impl.EventServiceImpl$RemoteEventPacketProcessor.run(EventServiceImpl.java:630)
at com.hazelcast.util.executor.StripedExecutor$Worker.process(StripedExecutor.java:190)
at com.hazelcast.util.executor.StripedExecutor$Worker.run(StripedExecutor.java:174)
Pradeep Pydi.
