Telstra
Last activity: 18 Feb 2016 2:22 EST
To customize mobile app icon in android
hello , We have generated apk file for our application in pega 7.1.9 but it has by default pega icon,I tried to customize the icon by checking the option Customize icons and Splash Screens (adding the icon.zip) and even publish banner option from Mobile Tab in the application rule.But I am not able to see the desired icon.It is showing same pega icon.Can you plese tell me how can I achieve the requirement.
You may need to rebuild the mobile app. Stephanie Louis, can you confirm one way or another?
There are 2 separate issues:
To get custom branding for mobile app - yes you have to rebuild.
If you want the icon on the banner to change, you have to open the banner section rule (linked in mobile tab) and change the logo there.
Telstra
Hi Kevin and Stephanie
I had rebuilt the app and even in the banner from mobile tab of the application, I changed the icon.But not able to see the desired icon in the android mobile phone.
Here icon on the banner means ?
the image icon which appears above application name in android device ? is that correct ?
check this link for details if not already: https://pdn.pega.com/uploading-branding-assets/uploading-branding-assets#preparing_branding_assets
Telstra
yes thank you , but while downloading apk file we are getting STATUS FAIL
| tus | fail |
| Message | There has been an issue; please consult your system administrator |
| Operator ID | pradeepk |
| Requestor ID | H07260F90E243588F7426FC7CBE2185EB |
| Timestamp | Fri Feb 05 23:58:40 IST 2016 |
| Engine Version | PegaRULES 7.10 ML9 (coreAssemblyCached_719_730) |
i can't understand.
are we saying you are having issue downloading the build? Please share the full pega rules log for review.
Telstra
I had uploaded assets zip folder in app branding and customization by replacing the common assets folder pega svg file with my desired svg file from the sample pega assets zip.
I am able to take apk file .but the app icon is still pega default
I believe your assets.zip may not be right. Here is the online help:
You are here: Mobile > Custom mobile application > Branding mobile apps > Contents of the assets package
The package contains the following directories:
- android - Contains graphics for different screen resolutions for the Android platform:
- ic_launcher - An icon displayed on the desktop
- icon_android - An icon used in the notification bar when the location services are active
- splashlogo - A graphic displayed on the splash screen
- ios - Contains graphics for different screen resolutions for the iOS platform:
- Icon - An icon that is displayed on the desktop
- LaunchImage - A graphic that is displayed as the splash screen
- bootstrap - Where custom resources for the bootstrap application can be added to replace the default ones. The following settings can be customized:
- Company logo
- Background color
- Foreground text color
- Progress bar background color
- Progress bar color
The other two directories are not related to custom branding. They are used to upload custom modules:
- modules-android – Contains libraries and resource files needed for a custom module to run on Android devices
- modules-ios – Contains libraries and resource files needed for a custom module to run on iOS devices
Telstra
can you please share customized assets.zip such that I can see the folders and respective images.
Updated: 11 Feb 2016 12:18 EST
I do not have one, but I know a lot of customers have done that. You can download the sample assets.zip from the online help. For example, here is the one I downloaded from 7.2 release. Stephanie Louis, can you confirm this has not changed or not.
That is the latest. That works.
Telstra
Hi Kevin , I am getting operation fail message in building apk file.
Failure Reason
Exec Returned 1
this does not tell us much. were you able to build apk without custom branding? If yes, then you probably need to see if your zip is valid or not. More details from the logs should help as well.
Telstra
Ok Thank you
