Bank Frick
LI
Last activity: 2 Apr 2025 14:39 EDT
Creating a Kafka data set with JSON data transform (Refered another JSON datatransform for reusable objects/fields ) causing/throwing errors.
Hi Team,
We have created a kafka dataset referring JSON datatranform as mentioned in the below screenshot.
The main datatransform has referenced another JSON datatransform as it has the same object/fields.
When we configured the dataset in the dataflow(realtime) we are getting errors as mentioned below.
Hi Team,
2025-03-31 16:01:10,072 [ STANDARD] ( dataset.kafka.KafkaBrowseOperation) ERROR - Error deserializing stream while reading from Kafka topic com.pega.dsm.dnode.api.dataset.kafka.KafkaDataSet$KafkaDataSetBuilder$$Lambda$5062/0x0000000801fae040@3befa329
com.pega.pegarules.pub.PRRuntimeException: LegacyModelAspectInvokableRuleContainer.invoke-Exception com.pega.pegarules.pub.PRRuntimeException: Could not find Rule-Obj-Model MapAttributeObjectData with applies to class in the database
at com.pega.platform.executionengine.vtable.containers.internal.LegacyModelAspectInvokableRuleContainer.invoke(LegacyModelAspectInvokableRuleContainer.java:76) ~[execution-engine.jar:?]
at com.pega.platform.executionengine.vtable.internal.RuleDispatcherImpl.invokeModel(RuleDispatcherImpl.java:165) ~[execution-engine.jar:?]
at com.pega.decision.dsm.strategy.clipboard.DSMPegaAPI.applyModel(DSMPegaAPI.java:333) ~[prpublic.jar:?]
at com.pega.decision.dsm.strategy.clipboard.DSMPegaAPI.applyModel(DSMPegaAPI.java:304) ~[prpublic.jar:?]
at com.pega.dsm.kafka.api.serde.DataTransformSerde.deserializeWithUsageOfJsonDataTransform(DataTransformSerde.java:156) ~[d-node.jar:?]
at com.pega.dsm.kafka.api.serde.DataTransformSerde.deserialize(DataTransformSerde.java:108) ~[d-node.jar:?]
at com.pega.dsm.kafka.api.serde.LazyExceptionHandlingSerDe.deserialize(LazyExceptionHandlingSerDe.java:77) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataset.kafka.KafkaBrowseOperation.deserializeMessage(KafkaBrowseOperation.java:347) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataset.kafka.KafkaBrowseOperation.convertRecordToClipboardPage(KafkaBrowseOperation.java:302) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataset.kafka.KafkaBrowseOperation.processRecords(KafkaBrowseOperation.java:210) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataset.kafka.KafkaBrowseOperation.processRecords(KafkaBrowseOperation.java:167) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataset.kafka.KafkaBrowseOperation.processRecords(KafkaBrowseOperation.java:157) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataset.kafka.KafkaBrowseOperation.processRecordsAndComplete(KafkaBrowseOperation.java:149) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataset.kafka.KafkaBrowseOperation.lambda$browse$0(KafkaBrowseOperation.java:145) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.stream.DataObservableImpl$SafeDataSubscriber.subscribe(DataObservableImpl.java:353) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.stream.DataObservableImpl.subscribe(DataObservableImpl.java:55) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataflow.resilience.retry.RetryableBrowse$RetryableEmitter.produceRecords(RetryableBrowse.java:145) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataflow.resilience.retry.RetryableBrowse$RetryableEmitter.emit(RetryableBrowse.java:111) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.stream.DataObservableImpl$3.emit(DataObservableImpl.java:176) ~[d-node.jar:?]
at com.pega.dsm.dnode.api.dataflow.DataFlow$3.run(DataFlow.java:446) ~[d-node.jar:?]
at com.pega.dsm.dnode.api.dataflow.DataFlow$3.run(DataFlow.java:439) ~[d-node.jar:?]
at com.pega.dsm.dnode.util.PrpcRunnable.execute(PrpcRunnable.java:77) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataflow.DataFlowThreadContext.lambda$submitInput$8(DataFlowThreadContext.java:308) ~[d-node.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
at com.google.common.util.concurrent.TrustedListenableFutureTask$TrustedFutureInterruptibleTask.runInterruptibly(TrustedListenableFutureTask.java:125) ~[guava-25.1-jre.jar:?]
at com.google.common.util.concurrent.InterruptibleTask.run(InterruptibleTask.java:57) ~[guava-25.1-jre.jar:?]
at com.google.common.util.concurrent.TrustedListenableFutureTask.run(TrustedListenableFutureTask.java:78) ~[guava-25.1-jre.jar:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) ~[?:?]
at com.pega.dsm.dnode.util.PrpcRunnable$1.run(PrpcRunnable.java:69) ~[d-node.jar:?]
at com.pega.dsm.dnode.util.PrpcRunnable$1.run(PrpcRunnable.java:66) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.prpc.PrpcThreadFactory$PrpcThread.run(PrpcThreadFactory.java:164) ~[d-node.jar:?]
Caused by: com.pega.pegarules.pub.PRRuntimeException: Could not find Rule-Obj-Model MapAttributeObjectData with applies to class in the database
at com.pega.pegarules.data.internal.clipboard.mapping.ClipboardDataStreamMapAssembler.openRule(ClipboardDataStreamMapAssembler.java:183) ~[prprivate-data.jar:?]
at com.pega.pegarules.data.internal.clipboard.mapping.ClipboardDataStreamMapAssembler.handleApplyDataTransform(ClipboardDataStreamMapAssembler.java:156) ~[prprivate-data.jar:?]
at com.pega.pegarules.data.internal.clipboard.mapping.ClipboardDataStreamMapAssembler.handleMappingActions(ClipboardDataStreamMapAssembler.java:146) ~[prprivate-data.jar:?]
at com.pega.pegarules.data.internal.clipboard.mapping.ClipboardDataStreamMapAssembler.handleUpdateContext(ClipboardDataStreamMapAssembler.java:237) ~[prprivate-data.jar:?]
at com.pega.pegarules.data.internal.clipboard.mapping.ClipboardDataStreamMapAssembler.handleMappingActions(ClipboardDataStreamMapAssembler.java:140) ~[prprivate-data.jar:?]
at com.pega.pegarules.data.internal.clipboard.mapping.ClipboardDataStreamMapAssembler.assembleMap(ClipboardDataStreamMapAssembler.java:103) ~[prprivate-data.jar:?]
at com.pega.pegarules.data.internal.clipboard.mapping.json.ClipboardJSONMapAssembler.assembleMap(ClipboardJSONMapAssembler.java:77) ~[prprivate-data.jar:?]
at com.pega.pegarules.data.internal.clipboard.mapping.EntityMapBuilderImpl.buildEntityMapFromModel(EntityMapBuilderImpl.java:147) ~[prprivate-data.jar:?]
at com.pegarules.generated.model.ra_model_mapidnowwebhooknotificationkafkadatasettopega_84989e4bbf88193cc59b69e995f0cbd9.perform(ra_model_mapidnowwebhooknotificationkafkadatasettopega_84989e4bbf88193cc59b69e995f0cbd9.java:67) ~[?:?]
at com.pega.platform.executionengine.vtable.containers.internal.LegacyModelAspectInvokableRuleContainer.invoke(LegacyModelAspectInvokableRuleContainer.java:67) ~[execution-engine.jar:?]
Quick response can be appreciated.
Som Venkata Kumar
