Corrupted word in Flow when called from [Create Work] local action
I am getting a unreadable japanese value (corrupted) in a flow (pyStartCase) as a parameter value. It only happens when the japanese word passed to to flow by parameter, like FlowParameter <- param1.value if I pass japanese word directly to flow parameter , it does not happen. FlowParameter <- "こんにちは!"
Reproduce step:
1. Create a button on a section
2. Set [Create work] as action to the button above.
3. In Create work setting, set any case type and select pyStartCase Flow. ( pyStartCase Flow has one parameter , like Param1)
4. In the [Create work] setting area, set flow (pyStartCase) parameter Param1 <- paramT.value (paramT is a local parameter holds a japanese word)
Result:
1. In the Flow (.pyStartCase), getting an corrupted japanese word. Expect Japanese word value: こんにちは! Actuall getting : ????????≪????? ̄???
Does anyone know how to solve this? Thank you!
***Edited by Moderator: Pallavi to update platform capability tags, update Support Case details***
