Shell India market private limited
Last activity: 11 Sep 2023 23:58 EDT
When rule is not working on local action
I have two ratio button type properties (true/false) which is A&B. According to the requirement when both the A&B property values (YES/YES) is same, pop up should not come, when both A&B property values are different (Yes/No) a pop up should come. Here B property is editable property and A property is non editable property.
On editable property B actions tab, we have called one local action & when rule, however this when rule is not working. But the clipboard values are showing correctly.
Please advise if there is any way to achieve this.
***Edited by Moderator Marije to change Type from Discussion to Question***
