Maantic Inc
Last activity: 4 Sep 2017 10:26 EDT
Post value action is not working when call from textarea
Post value action is not working when call from textarea.
Textarea user inputs are not updated in clipboard. post value called in event on click and on change in the textarea.
Pega version 7.2.1
#UI
Likes (1)
Deepikaa N -
Hi John,
I don't see the same issue, it is working fine from my end. Can you share you configuration? Also are you using the current pxTextArea, and not some older control migrated from an earlier release?
Maantic Inc
Config details added. textarea section is configured in flow action, so it will display in a pop up
Hi John,
I tried a 'change' event with 'Post Value' action (instead of a 'click' event with 'Post Value' action) on the textarea. it works fine. The clipboard showed the correct user inputs.
Can you try the same and see the result?
Susan
Siemens
Hi John,
I had seen a similar issue with CPM portals. Could you confirm if the issue is happening in base PRPC or CPM portals ?
Also please post the screen shot of the exact configuration.
Maantic Inc
Siemens
As per my understanding only harness or a new url can be displayed in a a popup window. Flow action can be launched in a modal dialog.
Could you let us know how exactly is the flow action launched.
Maantic Inc
Flow action is called in Local action. target modal dialogue and modal format standard.
Siemens
Strange. i tried with the exactly same configuration as you have mentioned and it is working fine at our end.
It looks like a bug and might need some debugging.
Meanwhile do test once what Sravanthi has suggested below. Maybe that may help.
Hi John,
Do you mind adding more information on the config details added? I was unable to find any File Attachments that could give us more insight.
Maantic Inc
In original post screen print added
Matheswaran Ravichandran Indera Sarman
Macquarie Group
Hi Lochan,
I am facing a similar issue and posted under topic "Editable Text Input does not allow dynamically changing values"
Can you please help. Thanks!
-Rishabh
Hi Rishabh,
I see that you've posted here: Editable Text Input does not allow dynamically changing values and there's some active discussion going! We will keep an eye out on the post for you!
Shell
Hi John,
Can you add a Refresh action, after the post value, on change of the Text Area and retest the behaviour ?
If possible try using only refresh and check if you face the same issue.
Do let us know if you still face the same issue.
- Chinmai Sravanthi.
