Virtusa Consulting Services Private Limited
Posted: Jan 8, 2026
Last activity: Jan 12, 2026
Last activity: 12 Jan 2026 15:05 EST
Constellation: How do I apply a background color conditionally for a particular field value?
I need to display field values with conditional background colors
if the field value is 'Yes' should have a red color background,
if the field value is 'No' should have a green color background.
Is there a way to implement this in Constellation without using custom DX components?
@SRUJANM6
Changing colors for a specific control or use case is not recommended. You can use AppStudio-->Settings-->Themes to setup the styles across your application.
