Connect REST wizard not setting up response XML parsing correctly
Hello guys,
I am trying to integrate currency information of the European Central Bank to my Pega 7.3 app.
Currency information is provided here (http://www.ecb.europa.eu/stats/eurofxref/eurofxref-daily.xml) in XML format.
I used to connect REST wizard to generate the required rules.
When testing the information is received, but the currencies are not parsed correctly. The first one (USD) gets parsed the other ones are empty.
To reproduce it simply use the REST wizard with the above URL (request type GET) and let Pega build up the response parsing from the actual response.
As I see the Parse XML rule is set up properly.
Do you have any clues what the error's root cause might be?
Thanks.
