Lloyds Banking Group PLC
Last activity: 6 Jul 2020 4:11 EDT
Configuring an AWS Key Management Service keystore
Hi Team,
Is there any provision to configure the AWS Key store per application for enabling the encryption?
Currently there is an option to create AWS Key store and enable the PEGA platform to use that key store. With this way all the applications hosted on the same environment will end up using the same key for data encryption.
There is an ask from security architect to understand if separate keys can be used for different applications. Let me know if it is possible.
Thank You,
Surendra.PV
***Edited by Moderator Kayla to update Content Type from Discussion to Question***
