Mediatek Inc. China
CN
Last activity: 18 Nov 2015 10:25 EST
ClassNotFoundException: PRAppLoader when upgrading from 6.1 SP2 to 7.1.8
When I tried to upgrade our PEGA platform from version 6.1 SP2 to 7.1.8, this error came to us after running the upgrade.bat for 133 minutes 51 seconds.
I've checked the database, there is no table names PR_ASSEMBLEDCLASSES at all.
I'm wondering whether this table should be migrated from old database or not? I'm pretty sure that here's no error when I migrated tables from old database.
Does anyone know what is the root cause, and how to resolve it? Appreciate a lot.
[java] 2015-8-13 18:11:45 com.pega.pegarules.internal.bootstrap.PRMiniLoader
[java] 19830421: Will load phase 2 bootstrap from Pega-EngineCode:07-10-17
[java] Warn - NonVersionedJdbcJarReader - unable to load classes from the database: DB2 SQL Error: SQLCODE=-204, SQLSTATE=42704, SQLERRMC=BPMRULED.PR_ASSEMBLEDCLASSES, DRIVER=4.11.77
[java] 2015-8-13 18:12:33 com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl
[java] 19830421: PegaRULES classes will be loaded from jar files (and NOT the database)
[java] 2015-8-13 18:12:35 com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl
[java] 严é: Error initializing PRAppLoader
[java] java.lang.ClassNotFoundException: com.pega.pegarules.bootstrap.loader.PRAppLoader
[java] at com.pega.pegarules.internal.bootstrap.phase2.PRBaseLoader.findClass(PRBaseLoader.java:312)
[java] at java.lang.ClassLoader.loadClass(Unknown Source)
[java] at com.pega.pegarules.internal.bootstrap.phase2.PRBaseLoader.loadClass(PRBaseLoader.java:237)
[java] at java.lang.Class.forName0(Native Method)
[java] at java.lang.Class.forName(Unknown Source)
[java] at com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl.initializeAppLoader(PRBootstrapImpl.java:1134)
[java] at com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl._finishInitialization_privact(PRBootstrapImpl.java:250)
[java] at com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl.finishInitialization(PRBootstrapImpl.java:122)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
[java] at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
[java] at java.lang.reflect.Method.invoke(Unknown Source)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.checkForStartup(PRBootstrap.java:682)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:405)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:272)
[java] at com.pega.pegarules.pub.PegaRULES.main(PegaRULES.java:85)
[java] 2015-8-13 18:12:35 com.pega.pegarules.internal.bootstrap.PRBootstrap
[java] 19830421:
[java] ============ PegaRULES Bootstrap Configuration ============
[java] Date: Thu Aug 13 18:12:35 CST 2015
[java] Java Version: Sun Microsystems Inc. 1.6.0_30
[java] Configuration: file:/C:/Users/mtk40659/AppData/Local/Temp//PegaInstallTemp-13-August-2015-15.58.45/prbootstrap.properties
[java] Pega-EngineCode: 07-10-17
[java] JDBC Driver: com.ibm.db2.jcc.DB2Driver
[java] JDBC URL: jdbc:db2:// Proprietary information hidden:50000/bpmd2:fullyMaterializeLobData=true;fullyMaterializeInputStreams=true;progressiveStreaming=2;useJDBC4ColumnNameAndLabelSemantics=2;
[java] JDBC User: bpmruled
[java] Database: DB2/LINUXX8664 SQL09073
[java] Driver: IBM Data Server Driver for JDBC and SQLJ 4.11.77
[java] Active CodeSets: pega-enginecode:07-10-17 at (latest patch)
[java]
[java] =============== End Bootstrap Configuration ===============
[java]
[java] 2015-8-13 18:12:35 com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega
[java] 严é: Problem during method invocation (main)
[java] java.lang.RuntimeException: PRAppLoader was not properly initialized, unable to load class com.pega.pegarules.deploy.internal.util.ImportImpl
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.getImplementationOf(PRBootstrap.java:205)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.getEntry(PRBootstrap.java:321)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.getMethod(PRBootstrap.java:301)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:406)
[java] Exception in thread "main" java.lang.RuntimeException: Problem during method invocation (main)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:278)
[java] Caused by: java.lang.RuntimeException: PRAppLoader was not properly initialized, unable to load class com.pega.pegarules.deploy.internal.util.ImportImpl
[java] ... 1 more
The pr_assembledclasses table existed in 6.1sp2 and should certainly exist in 7.1.8. Is this an upgrade to a single or split schema? Assuming this is a split schema upgrade did you successfully migrate the rules tables from your existing 6.1sp2 single schema to the new rules schema BPMRULED and now you are running the rules schema upgrade? Please post the complete upgrade log.
Mediatek Inc. China
CN
Hi Celeste,
Thanks for your reply.
Yeah, we're upgrading our PRPC to split-schema database - it use to be single schema in version 6.1.
There're total 40 tables were migrated to new rules schema from old database, and no PR_ASSEMBLEDCLASSES was migrated.
Meanwhile, the migration was succeeded.
Mediatek Inc. China
CN
Complete upgrade log as below.
Targets:Upgrade
Unable to locate tools.jar. Expected to find it in C:\Program Files\Java\jre6\lib\tools.jar
Buildfile: D:\Software\Install\Work\PRPC_V7.1.8\114819_Pega718\.\pegaGuiInstallerTemp\build.xml
SetupProperties:
Upgrade:
[echo] calling upgrade ....
upgrade:
Initialization:
[echo] Performing Upgrade Finalization
[echo] Using logging configuration from: ./config/deploylogging.properties
[delete] Deleting: D:\Software\Install\Work\PRPC_V7.1.8\114819_Pega718\scripts\resume.properties
[delete] Deleting directory D:\Software\Install\Work\PRPC_V7.1.8\114819_Pega718\scripts\taskRuntimes
[mkdir] Created dir: D:\Software\Install\Work\PRPC_V7.1.8\114819_Pega718\scripts\taskRuntimes
[delete] Deleting: D:\Software\Install\Work\PRPC_V7.1.8\114819_Pega718\scripts\logs\Warnings.log
Reading Properties from : D:\Software\Install\Work\PRPC_V7.1.8\114819_Pega718\scripts/setupDatabase.properties
pega.jdbc.driver.jar=D:\Software\Install\Work\PRPC_V7.1.8\114819_Pega718\scripts\lib\db2jcc4.jar
pega.jdbc.driver.class=com.ibm.db2.jcc.DB2Driver
pega.database.type=udb
pega.jdbc.url=jdbc:db2:// Proprietary information hidden:50000/bpmd2:fullyMaterializeLobData=true;fullyMaterializeInputStreams=true;progressiveStreaming=2;useJDBC4ColumnNameAndLabelSemantics=2;
pega.jdbc.username=bpmruled
pega.jdbc.password=******
rules.schema.name=bpmruled
Targets:Upgrade
SetupProperties:
Upgrade:
upgrade:
Initialization:
data.schema.name=bpmruled
user.temp.dir=D:\PEGA718_Upgrade_Temp
pega.zos.properties=
bypass.pega.schema=true
run.assembler=
import.assembled.classes=true
system.name=pega
production.level=2
multitenant.system=false
update.existing.applications=false
import.codeset.name=Customer
import.codeset.version=06-01-01
build.conclusions=
[propertyfile] Creating new property file: D:\Software\Install\Work\PRPC_V7.1.8\114819_Pega718\scripts\resume.properties
[propertyfile] Updating property file: D:\Software\Install\Work\PRPC_V7.1.8\114819_Pega718\scripts\resume.properties
Found 7373888KB of free space on 'C:\Users\mtk40659\AppData\Local\Temp\'
[echo] setting to generated ddl
[echo] Driver Path: D:\Software\Install\Work\PRPC_V7.1.8\114819_Pega718\scripts\lib\db2jcc4.jar
[mkdir] Created dir: C:\Users\mtk40659\AppData\Local\Temp\PegaInstallTemp-13-August-2015-15.58.45\load
[mkdir] Created dir: C:\Users\mtk40659\AppData\Local\Temp\PegaInstallTemp-13-August-2015-15.58.45\pr_temp
[touch] Creating D:\Software\Install\Work\PRPC_V7.1.8\114819_Pega718\scripts\logs\Warnings.log
[echo] Using C:\Users\mtk40659\AppData\Local\Temp\/PegaInstallTemp-13-August-2015-15.58.45 for install scratch space...
[unzip] Expanding: D:\Software\Install\Work\PRPC_V7.1.8\114819_Pega718\archives\prweb.war into C:\Users\mtk40659\AppData\Local\Temp\PegaInstallTemp-13-August-2015-15.58.45\load
[unzip] Expanding: D:\Software\Install\Work\PRPC_V7.1.8\114819_Pega718\archives\pegadbinstall-classes.zip into C:\Users\mtk40659\AppData\Local\Temp\PegaInstallTemp-13-August-2015-15.58.45\load
[copy] Copying 1 file to C:\Users\mtk40659\AppData\Local\Temp\PegaInstallTemp-13-August-2015-15.58.45\load\WEB-INF\classes
Checking Configuration Files:
[echo] Rules schema has been set to 'bpmruled'
[echo] ***writing resume property upgrade.from.version=06-01-25 to file***
[echo] Upgrading from Pega-RULES product version 06-01-25
Processing Configuration Files:
[propertyfile] Creating new property file: C:\Users\mtk40659\AppData\Local\Temp\PegaInstallTemp-13-August-2015-15.58.45\prbootstrap.properties
[propertyfile] Updating property file: C:\Users\mtk40659\AppData\Local\Temp\PegaInstallTemp-13-August-2015-15.58.45\udb.conf
Configuration:
[echo] Database Type: udb
[echo] JDBC Driver JAR: D:\Software\Install\Work\PRPC_V7.1.8\114819_Pega718\scripts\lib\db2jcc4.jar
[echo] Bootstrap Config: C:\Users\mtk40659\AppData\Local\Temp\/PegaInstallTemp-13-August-2015-15.58.45/prbootstrap.properties
[echo] PegaRULES Config: C:\Users\mtk40659\AppData\Local\Temp\/PegaInstallTemp-13-August-2015-15.58.45/prconfig.xml
[echo] PegaRULES Logging Config: C:\Users\mtk40659\AppData\Local\Temp\/PegaInstallTemp-13-August-2015-15.58.45/prlogging.xml
[echo] Deployment Logging Config: ./config/deploylogging.properties
Cleanup RuleSets:
Generate RuleSet Cleanup Script:
[echo] Generating Cleanup Script: D:\PEGA718_Upgrade_Temp/PRPC-RulesetCleanup.sql
[java] Version size : 1
[java] Error : The file could not be created due to an IO Error:
[java] D:\PEGA718_Upgrade_Temp\PRPC-RulesetCleanup.sql (The system cannot find the path specified)
[java] The script 'PRPC-RulesetCleanup.sql' has been created in the specified directory
Execute RuleSet Cleanup Script:
[echo] File not found: D:\PEGA718_Upgrade_Temp/PRPC-RulesetCleanup.sql
[echo] Skipping RuleSet Cleanup...
Generate Upgrade DDL:
[echo] Bypassing DDL generation...
Schema Upgrade:
[echo] Skipping automatic schema upgrade because bypass.pega.schema is set to true
Apply UDFs:
Apply UDFs Inner:
[echo] ***setting resume checkpoint***
Engine Load:
Engine Load Inner:
[java] 2015-8-13 15:59:34 com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource
[java] 19830421: Loading bootstrap properties from file:///C:\Users\mtk40659\AppData\Local\Temp\/PegaInstallTemp-13-August-2015-15.58.45/prbootstrap.properties
[java] 2015-8-13 15:59:34 com.pega.pegarules.internal.bootstrap.SettingReaderJNDI
[java] 19830421: Could not find java:comp/env/prbootstrap/ in the local JNDI context, skipping prconfig setting lookup
[java] 19830421: Could not find prbootstrap in the local JNDI context, skipping prconfig setting lookup
[java] 19830421: Engine schema defined in allclasses: null
[java] 19830421: Could not find java:comp/env/prconfig/ in the local JNDI context, skipping prconfig setting lookup
[java] 19830421: Could not find prconfig in the local JNDI context, skipping prconfig setting lookup
[java] 19830421: Engine classes schema: null
[java] 19830421: Assembled classes schema: null
[java] 2015-8-13 17:48:26 com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool$ContentElement addUnique
[java] è¦å: Duplicate entry for prlogging.xml in jar prresources.jar (DIFFERENT)
[java] 2015-8-13 15:59:36 com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool processOneJar
[java] ä¿¡æ¯: Storing: base\activation-1.1.1.jar (because it is signed)
[java] 2015-8-13 15:59:53 com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool processOneJar
[java] ä¿¡æ¯: Storing: base\java6\bcmail-jdk15on-149.jar (because it is signed)
[java] 2015-8-13 15:59:54 com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool processOneJar
[java] ä¿¡æ¯: Storing: base\java6\bcpkix-jdk15on-149.jar (because it is signed)
[java] 2015-8-13 15:59:56 com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool processOneJar
[java] ä¿¡æ¯: Storing: base\java6\bcprov-jdk15on-149.jar (because it is signed)
[java] 2015-8-13 16:02:28 com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool processOneJar
[java] ä¿¡æ¯: Storing: avalon-framework-4.0-dsm.jar (because it must be extracted)
[java] 2015-8-13 16:02:55 com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool processOneJar
[java] ä¿¡æ¯: Storing: batik-1.5-fop-0.20-5-dsm.jar (because it must be extracted)
[java] 2015-8-13 16:06:32 com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool processOneJar
[java] ä¿¡æ¯: Storing: chemistry-opencmis-commons-impl-0.12.0.jar (because it must be extracted)
[java] 2015-8-13 16:20:52 com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool processOneJar
[java] ä¿¡æ¯: Storing: fop-0.20.5-dsm.jar (because it must be extracted)
[java] 2015-8-13 16:42:27 com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool processOneJar
[java] ä¿¡æ¯: Storing: pad-reporting-7.1.8.jar (because it must be extracted)
[java] 2015-8-13 16:47:16 com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool processOneJar
[java] ä¿¡æ¯: Storing: praddressing-1.5.4.jar (because it must be extracted)
[java] 2015-8-13 16:48:33 com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool processOneJar
[java] ä¿¡æ¯: Storing: praxiom-1.2.13.jar (because it must be extracted)
[java] 2015-8-13 16:49:25 com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool processOneJar
[java] ä¿¡æ¯: Storing: praxis2-1.6.2.jar (because it must be extracted)
[java] 2015-8-13 17:02:27 com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool processOneJar
[java] ä¿¡æ¯: Storing: prhazelcast-3.4.1.jar (because it must be extracted)
[java] 2015-8-13 17:02:39 com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool processOneJar
[java] ä¿¡æ¯: Storing: prhttpcomponents-client-4.1.2.jar (because it must be extracted)
[java] 2015-8-13 17:02:40 com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool processOneJar
[java] ä¿¡æ¯: Storing: prhttpcomponents-core-4.1.3.jar (because it must be extracted)
[java] 2015-8-13 17:09:36 com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool processOneJar
[java] ä¿¡æ¯: Storing: prneethi-3.0.2.jar (because it must be extracted)
[java] 2015-8-13 17:48:24 com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool processOneJar
[java] ä¿¡æ¯: Storing: prrahas-module-1.6.2.jar (because it must be extracted)
[java] ä¿¡æ¯: Storing: prrampart-core-1.6.2.jar (because it must be extracted)
[java] 2015-8-13 17:48:25 com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool processOneJar
[java] ä¿¡æ¯: Storing: prrampart-module-1.6.2.jar (because it must be extracted)
[java] 2015-8-13 17:48:26 com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool processOneJar
[java] ä¿¡æ¯: Loading: prresources.jar (no signature data exists in database)
[java] ä¿¡æ¯: Omitting file: prresources.jar /prlogging.xml
[java] 2015-8-13 17:52:10 com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool processOneJar
[java] ä¿¡æ¯: Storing: saxon9he.jar (because it is signed)
[java] 2015-8-13 18:11:43 com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool reportOutput
[java] ä¿¡æ¯: Count of jar files: 270
[java] ä¿¡æ¯: Count of jar files loaded: 270
[java] ä¿¡æ¯: Count of jar files skipped: 0
[java] ä¿¡æ¯: Count of packages: 5732
[java] ä¿¡æ¯: Count of classes: 91915
[java] ä¿¡æ¯: Count of other resources: 18835
[java] ä¿¡æ¯: = Total entries: 110750
[java] ä¿¡æ¯: Count resources loaded: 110729
[java] ä¿¡æ¯: Count resources not loaded: 1
[java] ä¿¡æ¯: Count jars stored: 20
[java] ä¿¡æ¯: Uncompressed size: 391605190
[java] ä¿¡æ¯: Jar compressed size: 150492055 -> 38.4295353695389% of uncompressed size
[java] ä¿¡æ¯: Total processing time: 7926.571 seconds
[java] ä¿¡æ¯: Read entry data time: 10.743 seconds
[java] ä¿¡æ¯: Longest package name: com/pega/elasticsearch/common/jackson/dataformat/yaml/snakeyaml/external/com/google/gdata/util/common/base (106)
[java] ä¿¡æ¯: Longest class name: OldRuleResolver$RuleResolutionSecondLevelCandidatesForCircumstancesMap$CandidateListForCircumstance.class (105)
Reorganize Database Indexes Preupgrade:
_getSystemName:
_findSystemName:
[echo] select max(s.pySystemName) from BPMRULED.pr_data_admin s inner join BPMRULED.pr_data_admin r on s.pySystemName = r.pySystemName where s.pxobjclass = 'Data-Admin-System' and r.pxObjClass = 'Data-Admin-Requestor'
[echo] System Name: prpc
[replace] Replaced 1 occurrences in 1 files.
_importPreupgrade:
[echo] about to Import Rules from : D:\Software\Install\Work\PRPC_V7.1.8\114819_Pega718\scripts/../rules//preupgrade.jar ...
[java] 2015-8-13 18:11:45 com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource
[java] 2015-8-13 18:11:45 com.pega.pegarules.internal.bootstrap.SettingReaderJNDI
[java] 19830421:
[java] 19830421: *=================================================================*
[java] 19830421: prbootstrap.properties entry "initialization.settingsource=file"; note that
[java] 19830421: this excludes use of entries in Data-Admin-System-Settings as prbootstrap settings
[java]
[java] 19830421:
[java]
[java]
[java] ... 1 more
BUILD FAILED
D:\Software\Install\Work\PRPC_V7.1.8\114819_Pega718\pegaGuiInstallerTemp\build.xml:83: The following error occurred while executing this line:
D:\Software\Install\Work\PRPC_V7.1.8\114819_Pega718\scripts\setupDatabase.xml:317: The following error occurred while executing this line:
D:\Software\Install\Work\PRPC_V7.1.8\114819_Pega718\scripts\setupDatabase.xml:2570: Java returned: 1
Total time: 133 minutes 51 seconds
Mediatek Inc. China
CN
Migration tables list (from migration log):
Wed Aug 12 20:38:58 CST 2015 (INFO):
Wed Aug 12 20:38:58 CST 2015 (INFO): PegaBulkMover: Table + PR_SYS_HOTFIX_EVENTS Load completed 0 Rows loaded
Wed Aug 12 20:38:58 CST 2015 (INFO): Processed 40 of 40 table(s)
Wed Aug 12 20:38:58 CST 2015 (INFO): Ending Time: Wed Aug 12 20:38:58 CST 2015
Wed Aug 12 20:38:58 CST 2015 (INFO): Elapsed Time: 33 hour(s), 25 minute(s), 21 second(s).
Tables:
PR_SYS_DECCHG
PR4_RULE_LIBRARY
PR_INDEX_REFERENCE
PR4_RULE_RULESET
PR_APP_BRANCH_IDX
PR4_FIELDVALUE
PR4_RULE_FLOW
PR_CHANGELOG
PR_ENGINECLASSES
PR4_RULE_USECASE
PR_DATA_ADMIN_PRODUCT
PR4_RULE_REQUIREMENT
PR_DATA_RULE_APPMETADATA
PR4_RULE
PR_DATA_SCANNER
PR_INDEX_CSS
PR4_RULE_VW
PR_INDEX_PRIVILEGE
PR_SYS_CONTEXT
PR4_RULE_TESTCASE
PR4_RULE_DECLAREPAGES
PR4_RULE_PROPERTY
PC_INDEX_FLOWREF
PR4_RULE_AUTOTEST
PR_INDEX_DATASOURCES
PR_LINK_USECASE
PR4_RULE_FILE_BINARY
PR4_BASE
PR4_RULE_SHORTCUT
PR_INDEX_RULE_AGENTS
PR_INDEX_CUSTOMFIELDS
PR4_RULE_FILE
PR_INDEX_WARNINGS
PR4_RULE_SYSGEN
PR4_RULE_MESSAGE
PR_REFERENCE_PAGE
PR_INDEX_CIRCUMSTANCE_DEF
Tables:
PR_SYS_DECCHG
PR4_RULE_LIBRARY
PR_INDEX_REFERENCE
PR4_RULE_RULESET
PR_APP_BRANCH_IDX
PR4_FIELDVALUE
PR4_RULE_FLOW
PR_CHANGELOG
PR_ENGINECLASSES
PR4_RULE_USECASE
PR4_RULE
PR_DATA_SCANNER
PR_INDEX_CSS
PR4_RULE_VW
PR_INDEX_PRIVILEGE
PR_SYS_CONTEXT
PR4_RULE_TESTCASE
PR4_RULE_PROPERTY
PC_INDEX_FLOWREF
PR4_RULE_AUTOTEST
PR_LINK_USECASE
PR4_BASE
PR4_RULE_SHORTCUT
PR4_RULE_FILE
PR_INDEX_WARNINGS
PR4_RULE_SYSGEN
PR4_RULE_MESSAGE
PR_REFERENCE_PAGE
PR4_RULE_DELEGATIONCONFIG
In looking at your upgrade log you have bypass.pega.schema=true. Did you genereate and apply the upgrade ddl after the migration and before starting to run this upgrade? The migrate script just copies the pr_data_admin table and the needed rules tables to the new schema. The rules upgrade is going to make the schema changes needed to upgrade to 7.1.8 and then upgrade the rules schema. Set bypass.pega.schema=false if you have not run the generateddl script and applied it and then restart this upgrade.
Updated: 19 Aug 2015 7:52 EDT
JP
Hi Celeste,
Both with and without bypass.pega.schema=true has been tried with no benefits.
Now we are trying the command line :upgrade.bat: --rulesShecma, which qives a tablespace error and we’re trying to fix it now.
After making few changes to the setupDatabase.properties [PFA ], when I ran upgrade.bat –rulesSchema,
I’ve got an error as below; and unfortunately, this is the only message I can find from the log file.
Buildfile: build.xml does not exist!
Build failed––––
Exiting with Error
Requesting for further steps to make the upgrad.bat, work as expected, which is presently existing without being able to locate build.xml
Also , any suggestion for trying a Split schema at this stage are welcome.
Note: Customer does not have a Applicaiton Server, only trying to upgrade the DB.
Kindly share any insights/best-practices/experiences so upgrades to ML 8.
Tarun Sipani
In your setupDatabase.properties file change this property so that it is not set.
# Generate schema will be skipped if this property is set to true
# Note: Leave this property blank if you need to generate the schema
To:
bypass.pega.schema=
Please post the logs from when the upgrade script with bypass.pega.schema not set to true. You do not need to pass any parameters on the command line for the rules schema upgrade if you have populated the setupDatabase.properties file.
You would just run the command like this:
upgrade.bat
Mediatek Inc. China
CN
Hi Celeste,
Thanks for your answer.
We'll try again with "bypass.pega.schema=", and will post the logs here.
However, we have ran the upgrade.sh successfully with "bypass.pega.schema=true", although there're 149 extra tables was created - originally, there're only 40 tables was migrated from old database to new rules schema.
We're wondering that what is the correct number of tables should be existed in the RULES schema?
How can we upgrade successfully without creating those extra tables?
We also found that some of those created extra tables have data stored in; so, can those tables be dropped after the upgrade?
Updated: 20 Aug 2015 22:38 EDT
JP
Dear SME,
Customer is able to used the "upgrade" commands.
Now the only question, is the missing clarity around :
1) Right no of tables, list of them, to compare and determine whether a success/failure situation has been achieved.
The Customer end is pressing to quickly determine, any such information from the SME would be hugely appreciated.
Thanks and Regards,
Tarun Sipani
Adding the upgrade logs tried, with “bypass.pega.schema=” , kindly advise , how to validate this as success and expected nos of tables
So the migrate to the new rules schema and the upgrade of the rules schema is completed. Has the rest of the upgrade been completed (second pass of migrate script, upgrade of data schema, running of additional scripts since upgrading from pre 62, etc) or are you just looking to verify where things stand at the end of the upgrade of the rules schema step? If you are just trying to verify that the upgrade of the rules schema has completed successfully before moving on to the rest of the upgrade comparing a list of tables is not what you should be doing. You should be looking at the upgrade log to make sure that all of the tasks completed without issue. If you post the log here I can look at it if you want.
Updated: 20 Aug 2015 22:46 EDT
JP
Hi Celeste,
Very sorry for the trouble, pfa the upgrade logs.
Do let me know if any other detail is required.
Thanks and Kind Regards,
Tarun Sipani
Updated: 21 Aug 2015 1:37 EDT
JP
Hi Celeste,
1) Yes we request you to please have a look in the upgrade logs attached.
Thank you very much for reminding about the other steps for this 6.1 SP2 to ML8 upgrade [I am referring Pega718_UpgradeGuide]
Request you to please let us know the part in the log indicator-of-sucess, if possible.
I could find :
~cleanup.sh
~ResourceKit\AdditionalUpgradeScripts [upgrade query on specific DB]
2) Is there any additional action to be taken apart from the above.
P.S.
Presently, this is single schema [Rules and Data].
I am a little confused by these log files as to what you have run and why. These are in general the steps that you need to run to upgrade from 6.1sp2 to 7.1.8 split schema. In the end you will have a new rules schema and what was your combined 6.1sp2 schema will be the 7.1 data schema. I'm assuming that you are following the upgrade to split schema with 1 database process from the upgrade guide.
1. Run migrate script to clone rules tables from combined 61sp2 schema (Combined61sp2) in new rules schema (NewRules)
2. Run upgrade script to upgrade new rules schema (NewRules). As part of this step dummy data tables will be added to rules schema.
3. Run migrate script (with target dataschema=Combined61sp2, target rulesschema=NewRules) to generate rules schema objects, grants between schemas
4. Run upgrade script with dataOnly option to upgrade dataSchema. RulesSchema=NewRules, DataSchema=Combined61sp2
5. Post upgrade steps include running additional scripts since you upgraded from pre-62, setting up app server, running optimize schema tool to clean up dummy data tables from NewRules schema and old rules tables from Combined61sp2 schema which is your new data schema, etc.
From the log labeled rule_upgrade0819.log it looks like that covers step #2. There seems to be an issue with badtablemapping with the pr_sys_statusnodes table but for the most part this upgrade completed successfully. However then this data_upgrade_0821.log I am not at all sure what you were attempting to do. It seems like you ran the upgrade script again but only set the data.schema.name=your new rules schema and then you ran the upgrade script a third time with both data and rules schema set. Did you ever run the second pass of the migrate script (step #3)? We can probably fix this upgrade from the point where you are at now without too much difficultly instead of restarting from the beginning but I want to be sure that you understand what steps you should be following and if something is not clear in the Upgrade guide that will get that corrected.
Updated: 21 Aug 2015 9:29 EDT
JP
Hi Celeste,
We will work with customer to confirm the intend/actions-done.
Then list down the next plan for restoration / complete upgrade , for your review.
Your help on this is highly helpful.
Thanks and regards
Tarun
Updated: 24 Aug 2015 2:30 EDT
Mediatek Inc. China
CN
Hi Celeste,
What we're planning to do the upgrade is:
1. Run migrate script to clone rules tables from combined 61sp2 schema (db2bpmd) in new rules schema (bpmruled)
2. Run upgrade script to upgrade new rules schema (bpmruled).
O3. Run migrate script (with target dataschema=Combined61sp2, target rulesschema=NewRules) to generate rules schema objects, grants between schemas
3. Run upgrade script with dataOnly option to upgrade dataSchema. RulesSchema=bpmruled, DataSchema=db2bpmd
The reason that original step O3 wasn't ran is we thought we can use upgraded rules schema (bpmruled) directly, there seems no need to migrate upgraded rules schema back.
Anyway, we have all the database backup, so that the upgrade can be rollback anytime without re-run the previous steps.
We're gonna to run the upgrade again exactly follow your instruction, if the step O3 is required.
But, we still don't see what is the necessary of running step O3 - why cannot use the upgraded schema directly?
JP
Hi Celeste,
Would you kindly comment on the need of 2+2 times upgrades/migrates using the upgrade.sh and migrate.sh .
IMHO we are delliting the previous older rules post completing.
The customer is been given quotes from the upgrade guide, but still not satisfied.
Also, what is final proof of completion of activity.
Sorry for the too many questions , but please if you could explain the behind the sceens needs for it.
Would be much appreciated.
Thanking again,
Tarun Sipani
Sorry I was away last week. Yes, you do need to run the migrate script a second time as I said previously, regardless of whether you are using the upgraded schema directly or migrating the upgrade back to a new schema. In your case you are want to use the upgraded rules schema directly so you don't need to migrate that schema back but you need to create the rules schema objects and grants between this new rules schema and what will become your data schema.
Run migrate script (with target RulesSchema=bpmruled, DataSchema=db2bpmd) to generate rules schema objects, grants between schemas. The first six flags in the migrateSystem.properties file will be set to false and just these last 2 flags will be set to true for this pass.
### The following operations should only be run when migrating upgraded rules
#Generate the rules schema objects (views, triggers, procedures, functions). The objects will be created in the pega.target.rules.schema
#but will contain references to the pega.target.data.schema where appropriate.
pega.rules.objects.generate=true
#Apply the rules schema objects (views, triggers, procedures, functions) to pega.target.rules.schema.
pega.rules.objects.apply=true
Updated: 31 Aug 2015 6:51 EDT
JP
Hi Celeste,
Thank you for your help on this.
As advised we are trying to migrate.sh with the attached property file. [Attachment-1]
When I execute migrate.sh to migrate upgraded rules schema to new rules schema (from UPGRADE to NEW RULES schema), I’ve got error message as below. [Attach -2]
2015-08-27 17:00:33,754 ( SQLLoader) INFO - CREATE TABLE BPMRULED.PR_DATA_PRODUCTS
2015-08-27 17:00:33,761 ( SQLLoader) WARNING - Failed to execute SQL in file udb03150.sql
com.ibm.db2.jcc.am.SqlSyntaxErrorException: DB2 SQL Error: SQLCODE=-601, SQLSTATE=42710, SQLERRMC=BPMRULED.PR_DATA_PRODUCTS;TABLE, DRIVER=4.11.77
From the attached log file, you can find that the PR_DATA_PRODUCTS table was trying to be created twice.
Once at 2015-08-27 17:00:27,863, and the other was in 2015-08-27 17:00:33,754.
Request you to please have a look, why we getting this error, which looks like related to duplicates, creation.
Tarun
When are you running this step? Have you reverted the database, wiped out the BPMRULED schema and restarted this from the beginning and are now seeing this issue on the second pass of the migrate script after you have successfully migrated the rules to bpmruled schema and upgraded the rules schema? From the properties file at the very least your target username cannot be the rules schema user for this step. It needs to be a deployment user who can access both the rules and data schemas as part of this step will be to generate the grants needed between the schemas. But even with that issue it does not look like the bpmruled schema actually doesn't contain the tables that it should at this point.
pega.target.jdbc.username=bpmruled
pega.target.rules.schema=bpmruled
pega.target.data.schema=db2bpmd
JP
Hi Celeste,
Thank you for reply.
We are at step 3, and trying to proceed without starting from scratch.
Tarun
Mediatek Inc. China
CN
Hi Celeste,
Thanks a lot for you patience.
Actually, follow the instruction you provided last time, we have reverted all the database schema and restarted the upgrade from the very beginning.
What we have done includes:
- Restore the original rules & data schema - db2bpmd.
- Clear the new rules schema - bpmruled.
- Create a new upgrade schema - bpmupgrd.
- Start the upgrade from the very beginning.
- We've got the error at step 3 as per your provided steps:
Hi Celeste,
Regarding the user name, we're pretty sure that the privilege to do everything; so user name may not be the root cause.
The general instructions I gave you previously where assuming you were following the upgrade with 1 database process. If you are switching to upgrading with 2 databases then this will change the property settings for step #3.
Let's use your actual schema names to make this clear what you have done.
So the Combined61sp2=db2bpmd. If you are upgrading with 1 database then you only need one new rules schema so you would either have NewRules=bpmruled or NewRules=bpmupgrd. You would only need 2 new schemas if you are following the upgrade with 2 database process where you would have a temporary upgrade schema which you would migrate back to the actual new rules schema in step #3.
When you did steps #1 and #2 did you use the same NewRules schema for both steps and if so was it bpmruled or bpmupgrd? If you are not sure then attach the logs from when you ran these steps
Upgrade with 1 database process in general (one new schema=NewRules):
1. Run migrate script to clone rules tables from combined 61sp2 schema (Combined61sp2=db2bpmd) in new rules schema (NewRules=?)
2. Run upgrade script to upgrade new rules schema (NewRules=?). As part of this step dummy data tables will be added to rules schema.
Upgrade with 2 database process in general (2 new schemas temporary Upgrade and NewRules):
1. Run migrate script to clone rules tables from combined 61sp2 schema (Combined61sp2=db2bpmd) in new temporary rules schema (UpGrade)
2. Run upgrade script to upgrade new rules schema (Upgrade) As part of this step dummy data tables will be added to rules schema.
3. Run migrate script (with source rulesschema=Upgrade target dataschema=Combined61sp2, target rulesschema=NewRules) to migrate the Upgrade schema to NewRules schema and generate rules schema objects, grants between schemas
5. Post upgrade steps include running additional scripts since you upgraded from pre-62, setting up app server, running optimize schema tool to clean up old rules tables from Combined61sp2 schema which is your new data schema, etc.
Updated: 2 Sep 2015 5:32 EDT
JP
Hi Celeste,
Thank you very much for the detailed steps, I just confirmed below with the customer end.
1) We are using a third temporary-upgrade schema and then trying to migrate (Step #3) to the final Schema.
2) Steps 1 and 2 [from Upgrade with 2 database process in general (2 new schemas temporary Upgrade and NewRules):] have been completed.
Can we request you to please confirm the migrate properties to achieve this.
[Does any of the first 6 properties be changed to true, to migrate from upgrade to final schema]
Regards and Thanks,
Tarun
OK, so from what I am reading you are following this process:
Upgrade with 2 database process in general (2 new schemas temporary Upgrade=bpmupgrd and NewRules=bpmruled, Combined61sp2=db2bpmd that will become the new data schema)
1. Run migrate script to clone rules tables from combined 61sp2 schema (Combined61sp2=db2bpmd) in new temporary rules schema (UpGrade=bpmupgrd)
2. Run upgrade script to upgrade new rules schema (Upgrade=bpmupgrd) As part of this step dummy data tables will be added to rules schema.
3. Run migrate script (with source rulesschema=bpmupgrd source dataschema=bpmupgrd target dataschema=Combined61sp2, target rulesschema=bpmruled) to migrate the Upgrade schema to bpmruled schema and generate rules schema objects, grants between schemas
4. Run upgrade script with dataOnly option to upgrade dataSchema. RulesSchema=bpmruled, DataSchema=db2bpmd
For step #3 with this process you actually need to migrate the upgraded rules back to the new rules schema and then also generate the rules schema objects/grants between schemas. This is assuming that bpmupgrd has the upgraded rules tables and that the bpmruled schema is empty completely. In your migrateSystem.properties file you need to set the flags like this to do this step which will generate and apply the ddl changes needed to the bpmruled schema and then copy the content of the bpmupgrd schema into bpmruled. After it has done that it will create any triggers, stored procedures, etc. that are needed in the bpmruled schema and also issue the grants needed for the db2bpmd and bpmruled schemas to interact with each other.
pega.move.admin.table=false
pega.clone.generate.xml=true
pega.clone.create.ddl=true
pega.clone.apply.ddl=true
pega.bulkmover.unload.db=true
pega.bulkmover.load.db=true
Have you been able to finish step #3 correctly now and move on to the data schema upgrade?
JP
Hi Celeste, as its been holidays at Customer s end, will know on Monday.
Tarun
FYI, I will be away the next couple of weeks but I asked a colleague to keep an eye on this post in case you have any further questions.
Mediatek Inc. China
CN
We have finished all the database upgrade steps, and deployed the prweb in Weblogic with deployment plan.
But, when we tried to startup the application server form Weblogic console, we keep getting error message as below.
2015-09-23 14:45:11,183 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ MTKRDApp:01.01.01] (l.access.ConnectionManagerImpl) ERROR - Not returning connection 3 for database "pegadata" to the pool as it previously encountered the following error
User ID: System
Last SQL: SELECT distinct ASS.PXREFOBJECTKEY as ".pzInsKey" FROM PC_ASSIGN_WORKLIST ASS WHERE PXREFOBJECTCLASS LIKE '%-RD-Work-STA' AND PXTASKLABEL='AdminWorkList'
- com.ibm.db2.jcc.am.SqlSyntaxErrorException: DB2 SQL Error: SQLCODE=-204, SQLSTATE=42704, SQLERRMC=BPMRULED.PC_ASSIGN_WORKLIST, DRIVER=3.61.75
The problem is that schema BPMRULED was desined as RULES schema, so it shouldn’t contain table PC_ASSIGN_WORKLIST.
From the pr4_base table of RULES schema - BPMRULED, we can find that the class Assign-Worklist was mapped to PegaDATA. PC_ASSIGN_WORKLIST.
From the pr4_base table of Data schema – DB2BPMD, the class Assign-Worklist was still mapped to PegaRULES. PC_ASSIGN_WORKLIST.
User ID: System
From the log, we can find that seems the bootstrap was using DB2BPMD as the database schema.
We’re not sure whether this could be the root cause or not, and how to correct it.
<Sep 24, 2015 10:49:35 AM CST> <Emergency> <com.pega.pegarules.internal.bootstrap.SettingReaderJNDI> <BEA-000000> <Could not find java:comp/env/prbootstrap/ in the local JNDI context, skipping prconfig setting lookup>
Sep 24, 2015 10:49:35 AM com.pega.pegarules.internal.bootstrap.SettingReaderJNDI
<Sep 24, 2015 10:49:35 AM CST> <Emergency> <com.pega.pegarules.internal.bootstrap.SettingReaderJNDI> <BEA-000000> <Could not find prbootstrap in the local JNDI context, skipping prconfig setting lookup>
Sep 24, 2015 10:49:35 AM com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource
19830421: Bootstrap datatables schema: "DB2BPMD"
The default schemas set in deployment plan was:
- <variable>
<name>defaultDataSchema</name>
<value>db2bpmd</value>
</variable>
- <variable>
<name>defaultRulesSchema</name>
<value>bpmruled</value>
</variable>
What database user have you defined in your PegaRULES datasource? For the base datasource user you can use the data schema. If this is what you have then I expect the problem is that you did not deployed correctly so that both the app and plan are being picked up. You need to deploy at the directory structure level.
For example: the directory structure for ear deployments is:
<someDirectory>\app\prpc_wls_jee4.ear
<someDirectory>\plan\Plan.xml
You need to select <someDirectory> when you deploy from the WebLogic console so that both the ear and Plan.xml are used.
JP
Hi Celeste,
Thank you very much for reviewing the migrate system file. Customer confirmed successful completion of Step# 3.
Regards and Thanks,
Tarun Sipani
Mediatek Inc. China
CN
The final solution is using the original prweb.war, and with single Datasource of weblogic.
After that the server started, with errors, but it seems the functions work fine.
Hi Gavin,
While deploying PRPC ear in weblogic in Split-schema , choose following folder:
\Pega718\archives\prpc\weblogic\ear
and NOT \Pega718\archives\prpc\weblogic\ear\app
I believe, you were deploying PRPC ear by going ear from Pega719\archives\prpc\weblogic\ear\app.
