Tokio Marine HCC
Last activity: 4 Sep 2025 9:39 EDT
Clarification on File Upload, Download, and Delete Behavior with External S3 Integration
Hello Pega Support Team,
We are currently testing large file handling with a Constellation-based application (Pega version 8.7.6), which is integrated with an external Amazon S3 bucket. I would like your guidance on the following observations and questions:
Upload Behavior
We have set the DSS value to
1GB. -
Uploads of large files (e.g., ~300 MB) are working successfully without any issues.
Can you please confirm the mechanism used when uploading to S3? Specifically, is the file stream sent through the Pega application server and then uploaded to S3, or is it handled directly between the client browser and the S3 bucket (for example via pre-signed URLs)?
Download Behavior
While uploads succeed, downloads of similarly sized files are timing out.
Could you explain how the download is managed? Is the file first pulled from S3 into the Pega app server and then streamed to the client browser, or does Pega support direct browser-to-S3 download links?
What configurations or product capabilities are available to ensure that the maximum supported download size is aligned with the upload size (up to the DSS limit of 1GB)?
Delete Behavior
Upload Behavior
1GB. -
Download Behavior
Delete Behavior
File deletions are working correctly.
Could you confirm how the delete operation is executed? Is the delete request processed directly against the S3 bucket, or is it routed through the Pega application server first?
Performance Impact
If downloads and deletes are routed via the Pega app server, what are the performance implications for the application when handling large file transfers and operations?
Are there recommended configurations (timeouts, streaming settings, or alternative approaches) to reduce impact on application performance?
Your clarification will help us finalize our design for handling large files and ensure we are aligned with Pega best practices.
