Accenture
Accenture
Accenture
Posted: Apr 4, 2017
Last activity: Apr 5, 2017
Last activity: 5 Apr 2017 13:08 EDT
Circumstancing Question Pega 6.2
Hi ,
Below is one of the quiz questions in Circumstancing lesson. Can someone explain how is the correct answer as 4.
You wish to create a “CalculateRate” rule and specialize it so that the functionality of it is different based on the “AccountNumber” property: any AccountNumber in the 1000’s (1000-1999) should have this special functionality. Assuming that circumstancing is used to provide this specialization, and that the “CalculateRate” rule does not exist in the system, how many rules (at minimum) must be created?
Show More
Hi ,
You wish to create a “CalculateRate” rule and specialize it so that the functionality of it is different based on the “AccountNumber” property: any AccountNumber in the 1000’s (1000-1999) should have this special functionality. Assuming that circumstancing is used to provide this specialization, and that the “CalculateRate” rule does not exist in the system, how many rules (at minimum) must be created? (Choose One)
2
1
Circumstancing cannot be used to address this requirement.
4
3
Show Less
