changes are not reflecting to portal after checkin.
I save as one private section and made my changes thats reflecting to portal but once i do checkin the changes are not reflecting why.?
yaa the same rule is available so what can i do.?
hi sadhanag,
can u confirm whether the rule is circumstanced or not.
also try to perform the Revalidate and save for more details about the Revalidate and save Tool find the https://community.pega.com/sites/default/files/help_v722/procomhelpmain.htm .
yaa, the rule is (available and also circumstance). and my section refering the old rule version.
HI Sadhanag,
Can you please perform the clean restart of the server and check?
For your problem, there are quite a few things which you can do like:
1. If you are using a pega cloud server, then I would request you to open the SMA and check for cache sizes and try to clear them and try again.
2. If step1 doesn't help you then raise an SR with pega for Server Restart with Clear Cache.
3. Also, In some cases, if the rules which are not getting reflected are less in number, then you can go for revalidate and save of each rule or in a bulk.
Praveen.
Hi sadhanag
check whether the rule is available in the highest version ,also verify any circumstance is defined for this section.
Pranavi.
