CDH Action rule details not immediately visible in container response
Hi!
When I update an action rule in Pega CDH(for example the description field), that change is not immediately(it takes hours) visible in the CDH container service response.
I run some tests and my understanding is that the NBA strategy doesn't reload the action details, because I updated the strategy myself by adding a SetProperty shape with no configurations, and then the action details were retrieved correctly.
How to fix this issue?
Thank you!
@VasilicaN This is not usual behaviour, and any changes made to the action rule should be immediately visible if they have been checked in properly. Could you please tell me which version of CDH and the Pega platform you are using? Additionally, Is this is a multi-node environment, and have you checked for any pulse issues that might be causing other nodes handling the container service to be out of sync?
