Last activity: 26 Mar 2019 4:20 EDT
CanPerform rule is restricting the pyReassignAssignment
The requirement is to allow certain end users ( access group with user4 role) with an option to pull assignments from others worklist in Review harness. As a fix added stage level local action to on submit pyReassignAssignment is called after opening newAssignPage.
This works for an admin but can perform restricts opening the Assign- class as end user is not in Perform harness. Any way to fix this? Don't want to override the role as it might display all assignments to enduser
Hi
You can try creating a new Role and add it to Operator ID's. Roles are taken as "OR" condition so ideally it should work.
Regards
Bhavya
