WellsFargo
WellsFargo
WellsFargo
Posted: Oct 16, 2015
Last activity: Apr 21, 2017
Last activity: 21 Apr 2017 7:50 EDT
Can we extract the work attachments (especially of type file) using BIX?
Hello All,
Is it possible to extract the case attachment , especially of file category using BIX? Output mode is XML
Gowri
BIX will extract the property value as is. By default pyAttachmentStream will have the Base64 encoded value of the file attachment. You can extract the same Base64 value into a column in the target database or as a XML element or a CSV column. BIX will not convert it to the actual attachment file and put it in the extract folder. If this is your requirement, please raise an enhancement request with Pega.
